Second ignition switch failed? |
Sprout |
Aug 12 2019, 01:28 PM
Member Group: Members Posts: 125 Joined: 5-October 18 From: Kansas City Member No.: 22,544 Region Association: Upper MidWest |
A little guidance, please...I've replaced the ignition switch in my '73 1.7 FI twice now with Meistersatz parts, and the car is dead again. Has only been started a couple dozen times between these two switches. When I turn the key, I have lights on the dash and can hear the fuel pump engage, but the engine does not crank. Battery is at 12.5 and just installed a reman Bosch starter/solenoid. It can be push-started.
From what I've read the switches seem to fail fairly often, but only starting the car a dozen times per switch seems pretty ridiculous. Are the genuine Porsche switches that much better? Do you think I could have something shorting out the switch? The 914 key is the only thing on my keyring, so I know it's not an extra weight problem. When it's running, it runs great! |
Mblizzard |
Aug 14 2019, 07:38 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
It is just a fact of time and entropy that the efficiency of the starting system degrades over time. With a car that was designed to last 10 or less years there is no question that the resistance in the system has increased dramatically in 50 years.
Go only with the German part you can still get at the dealer and install either the Ford or modern relay to increase the effectiveness of an old and tired system. |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:16 AM |
