2.7 CIS, Another six conversion |
John |
Aug 13 2019, 09:09 AM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I tried searching, but didn't get much.
What is involved with fitting a 2.7 with CIS in a 914? I can figure out the plumbing and the electrical, but I believe that I had read long ago that it was a PITA to fit CIS without cutting anything or perhaps a mixture of different parts could be used or parts of the intake could be relocated in order to get it all to fit. I'd prefer to avoid cutting this 914 engine compartment since I'm trying to make this one appear mostly factory. Any advice or better yet pictures would be appreciated. I'd rather not go with carbs, since I believe that I'd need to swap cams and pistons in order to do it right. This one is only going to be a fun street car (I already have a dedicated track car) (All my conversion experience has been with 3.2s, but I have this body, and I have this engine...) Thanks in advance! |
Justinp71 |
Oct 1 2019, 05:48 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
My uncle and I did a 2.7 install 15 years ago. We had an earlier CIS that had less components (not sure when they added more components, but I know the 3.0 version has more for sure). We just removed the engine lid latch afaik and secured it with hood pins. You can also rotate it 180 degrees as from what others have said. If you have a later model CIS there is a valve on the back side that interferes with the trunk and I believe you need to rotate the CIS or make other modifications.
Lo-Fi Version | Time is now: 1st May 2024 - 10:21 PM |
