2.7 CIS, Another six conversion |
John |
Aug 13 2019, 09:09 AM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I tried searching, but didn't get much.
What is involved with fitting a 2.7 with CIS in a 914? I can figure out the plumbing and the electrical, but I believe that I had read long ago that it was a PITA to fit CIS without cutting anything or perhaps a mixture of different parts could be used or parts of the intake could be relocated in order to get it all to fit. I'd prefer to avoid cutting this 914 engine compartment since I'm trying to make this one appear mostly factory. Any advice or better yet pictures would be appreciated. I'd rather not go with carbs, since I believe that I'd need to swap cams and pistons in order to do it right. This one is only going to be a fun street car (I already have a dedicated track car) (All my conversion experience has been with 3.2s, but I have this body, and I have this engine...) Thanks in advance! |
morgan_harwell |
Aug 13 2019, 10:22 AM
Ha! Finally snuck up on a camera! Group: Members Posts: 126 Joined: 28-January 03 From: Santa Cruz Mtns., Ca. Member No.: 203 Region Association: Northern California |
I did this in 1987 with a 2.4L CIS engine. I did not need to cut up the engine bay or rotate the injection system in any direction.
1. I moved the engine lid latch assembly from the Driver's side to the Passenger side of the engine bay to make room for the CIS (requires some spot welds and making a longer release cable). The engine lid is designed for the latch pin assembly to be mounted on Driver's or Passenger side, so I moved it to the Passenger side on my original lid(again a couple of spot welds involved). Many years later, when I ordered a GT Lid from PCA7GGR, I had Sergio perform the same modification to the GT Lid before he painted it. 2. I relocated a CIS item from the rear-top of the CIS assembly (I think an altitude compensation part, has 3 hoses attached to it) to below the CIS assembly. I attached it to the lower part of the #6 intake manifold. 3. I replaced the fuel fitting on the back of the CIS Fuel Distributor. The original fitting came straight out of the FD directly into the rear firewall, so I replaced it with a welded up 90 degree banjo fitting. 4. I used the Becker Engineering 6-conversion mount at the time (1987). I will be switching that out this year (2019) for the Naro Mount, so that I can install the MB911 Heat Exchangers I bought a couple of years ago. |
Lo-Fi Version | Time is now: 20th April 2024 - 01:12 AM |
