2.7 CIS, Another six conversion |
John |
Aug 13 2019, 09:09 AM
I tried searching, but didn't get much.
What is involved with fitting a 2.7 with CIS in a 914? I can figure out the plumbing and the electrical, but I believe that I had read long ago that it was a PITA to fit CIS without cutting anything or perhaps a mixture of different parts could be used or parts of the intake could be relocated in order to get it all to fit. I'd prefer to avoid cutting this 914 engine compartment since I'm trying to make this one appear mostly factory. Any advice or better yet pictures would be appreciated. I'd rather not go with carbs, since I believe that I'd need to swap cams and pistons in order to do it right. This one is only going to be a fun street car (I already have a dedicated track car) (All my conversion experience has been with 3.2s, but I have this body, and I have this engine...) Thanks in advance! |
mb911 |
Aug 13 2019, 10:14 AM
914 Guru Group: Members Posts: 6,810 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
You actually rotate the cis 180 degrees and rebolt down.. It is pretty straight forward..
Let me know if I can help.. Also note the naro mount drops the height of the engine approximately 3/4" and will NOT allow for a stock scavange line.. |
John |
Aug 13 2019, 10:28 AM
You actually rotate the cis 180 degrees and rebolt down.. It is pretty straight forward.. Let me know if I can help.. Also note the naro mount drops the height of the engine approximately 3/4" and will NOT allow for a stock scavange line.. Do you know for a fact that it's possible to rotate the intake 180 degrees and have it fit or did you hear that second hand? I can try that on a stand and see if it all works before attempting to stuff it in the car. I will probably make my own mount and sheet metal again. It worked well with the 3.2s I did. P.S. I may want to talk to you about exhaust. |
Dr Evil |
Aug 13 2019, 11:01 AM
Send me your transmission! Group: Members Posts: 22,993 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
You actually rotate the cis 180 degrees and rebolt down.. It is pretty straight forward.. Let me know if I can help.. Also note the naro mount drops the height of the engine approximately 3/4" and will NOT allow for a stock scavange line.. Do you know for a fact that it's possible to rotate the intake 180 degrees and have it fit or did you hear that second hand? I can try that on a stand and see if it all works before attempting to stuff it in the car. I will probably make my own mount and sheet metal again. It worked well with the 3.2s I did. P.S. I may want to talk to you about exhaust. I have a conversion with a 2.7 running CIS. The you can rotate it no prob. Mine fit with minimal strife and modification. It is hours away from me at a body shop and the engine is out so cant take new pics, but if you search my conversion all the pics are there. |
Lo-Fi Version | Time is now: 25th April 2024 - 04:18 AM |
