2.7 CIS, Another six conversion |
John |
Aug 13 2019, 09:09 AM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I tried searching, but didn't get much.
What is involved with fitting a 2.7 with CIS in a 914? I can figure out the plumbing and the electrical, but I believe that I had read long ago that it was a PITA to fit CIS without cutting anything or perhaps a mixture of different parts could be used or parts of the intake could be relocated in order to get it all to fit. I'd prefer to avoid cutting this 914 engine compartment since I'm trying to make this one appear mostly factory. Any advice or better yet pictures would be appreciated. I'd rather not go with carbs, since I believe that I'd need to swap cams and pistons in order to do it right. This one is only going to be a fun street car (I already have a dedicated track car) (All my conversion experience has been with 3.2s, but I have this body, and I have this engine...) Thanks in advance! |
John |
Sep 2 2019, 08:33 PM
Well, I repaired the passenger side outer longitudinal with a replacement part from RD and all went fine so I'll continue on with this car. I was surprised with the absence of rust inside the the box section that I replaced. I still need to grind down my plug welds. In general, this car is mostly rust free, but it had been in at least a few crashes.
It does measure out, according to the workshop manuals. Now I get to proceed on to re-fitting the 75 front fenders and back dating them as well as modifying the miscellaneous reinforcements for the front trunk (the front panel is obviously different from the earlier cars that I have). Does a stock 2.7 need a front cooler? I'm not sure, but if it needs one, I may want to mount the lines like a GT on the drivers side under the rocker panel. My last conversion, I went through the heater tubes as it has headers and no heat anyway, but now some folks seem to offer heat exchangers for conversion cars... |
Lo-Fi Version | Time is now: 8th May 2024 - 07:18 AM |
