Rod Orientation, Do I have it right? |
Mblizzard |
Aug 13 2019, 11:36 AM
Thanks to a suggestion from Shane I have been running through my plans for assembly and was thinking about the orientation of the rods. The rods have some cryptic instructions that I took to mean to install the oil hole on the top of the rod facing towards the top of engine. Which is how I had installed them in the past builds.
Not my picture but this is how I installed the rods. To me this makes sense as the oil coming out would run down on parts. The other way would potentially leave the top dry. Because the guidance provided with the rods was not very clear I thought I would ask since I have the chance to change. |
Mark Henry |
Aug 13 2019, 03:01 PM
They're not directional, it doesn't matter.
If you don't want to freak out the next engine builder install them tangs down. (IMG:style_emoticons/default/wink.gif) Some rods like VW T1 stock rods are directional because they have an offset. Easy to check put a straight edge across the big end, check both sides, if they have an offset you'll see it in relation to the small end. |
Lo-Fi Version | Time is now: 23rd April 2024 - 08:59 PM |
