Emergency brake warning light, emergency brake warning light |
9fourteen14 |
Aug 13 2019, 12:52 PM
PORSCHE LUVA Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States |
so i have a 74 2.0 914
problem: my emergency brake light continues to flash even when i raise the emergency brake. I got pelican parts diagnosis and possible cure but i don't think i have the same switch because i do not see a little plastic button i can switch towards the master cyclinder. see pictures below. BTW: my switch is rusted a lot. there are 2 varieties pelican points out:1: low pressure when pedal is pushed to floor and reset hen lift off floor (I am NOT seeing that) 2: pressure failure and then remains locked until manually reset. WHERE IS THE BUTTON TO RESET IT? I DO NOT SEE IT? check out the 2 pictures.... any other ideas? thanx Niece Attached thumbnail(s) |
Spoke |
Aug 13 2019, 07:23 PM
Jerry Group: Members Posts: 6,976 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
If you remove the wire on the MC switch, does the brake warning light go out? The e-brake handle switch is in parallel to the MC switch. Either one of those can cause the brake warning light to light up.
Lo-Fi Version | Time is now: 26th April 2024 - 07:35 AM |
