Emergency brake warning light, emergency brake warning light |
9fourteen14 |
Aug 13 2019, 12:52 PM
PORSCHE LUVA Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States |
so i have a 74 2.0 914
problem: my emergency brake light continues to flash even when i raise the emergency brake. I got pelican parts diagnosis and possible cure but i don't think i have the same switch because i do not see a little plastic button i can switch towards the master cyclinder. see pictures below. BTW: my switch is rusted a lot. there are 2 varieties pelican points out:1: low pressure when pedal is pushed to floor and reset hen lift off floor (I am NOT seeing that) 2: pressure failure and then remains locked until manually reset. WHERE IS THE BUTTON TO RESET IT? I DO NOT SEE IT? check out the 2 pictures.... any other ideas? thanx Niece Attached thumbnail(s) |
914Sixer |
Aug 13 2019, 01:04 PM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
NO reset on that one. There was a two pole (70-73), one pole (as shown) and a one pole with plastic reset shown is picture.
Have you checked to make sure the switch button is all the way out when you pull the lever up. Attached image(s) |
Lo-Fi Version | Time is now: 19th April 2024 - 08:07 PM |
