Window rollers |
Window rollers |
partwerks |
Aug 13 2019, 08:20 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Are these those rollers in the guide? Found one in the bottom of the door split in two. Appears there is a roller already in there, or is there more than one in each door?
Attached image(s) |
Mikey914 |
Aug 13 2019, 09:48 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
There are 4 per car 2 on each window. Part of the scissor assembly not sold alone. That's why we made them (IMG:style_emoticons/default/biggrin.gif)
https://900designs-container.zoeysite.com/w...r-two-regulator Attached thumbnail(s) |
partwerks |
Aug 13 2019, 09:55 PM
I didn't readily see where the other one is located at then?
Mikey914 |
Aug 13 2019, 10:02 PM
Here
Window base and part 3 Attached thumbnail(s) |
jim_hoyland |
Aug 14 2019, 05:03 AM
Get that VIN ? Group: Members Posts: 9,261 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
How do you replace them ? I bought a pair for my '75 and Drew a blank when I opened the door.... (IMG:style_emoticons/default/huh.gif)
partwerks |
Aug 14 2019, 05:23 AM
How do you replace them ? I bought a pair for my '75 and Drew a blank when I opened the door.... (IMG:style_emoticons/default/huh.gif) I was wondering the same. Maybe it's not as bad as it looks. |
Mikey914 |
Aug 14 2019, 08:43 AM
Actually not too bad. The nylon old ones tend to come off in pieces, but if they don't they can be popped off with a pliers. You can use a pliers to press the new ones on. They will not break, but it takes less pressure if you drop them in hot water for about a minute.
Lo-Fi Version | Time is now: 25th April 2024 - 02:24 PM |
