Our first wheel/tire thread |
campbellcj |
Dec 31 2002, 09:04 PM
I can't Re Member Group: Members Posts: 4,540 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I'm currently running 15x7 cookie cutters with Kumho Ecsta V700 205/50's.
For my 2nd set of track wheels, I'd like to run Hoosiers and would prefer to go 16x7's instead of 15's. (This is a stock bodied car). What are the odds I could squeeze some 215/40 Hoosiers under the car, on 16x7's? I am more worried about the fronts than the rears, as the rear fenders were significantly rolled and pulled and have a bunch of extra room with the current rubber. The Hoosiers do not seem to be available in a 205/55R16 or 205/50 size, so my only other option looks like sticking with 205/50R15's (?) I was hoping to have a "short" set and a "taller" set for different tracks. Obviously the 215/40R16's will still be a short tire with a big gearing impact. |
Porsche Rescue |
Dec 31 2002, 09:44 PM
I have 205/45x16 on 7" Fuchs on a stock car. The rear lips are rolled. I have no problem on the front. I relied on Tire Rack's specs for dimensions in comparing sizes.
If your rears are pulled a bit, 215's should work. I recently owned (briefly) a '70 six with 215/60x15 on 6" Fuchs with slight rub in front on a hard bump. Rear's did not rub but less than a quarter inch clearance on outside. Rear springs were real stiff. If not, it surely would have rubbed in the rear. |
drew365 |
Jan 1 2003, 10:18 AM
This probably won't help you since I have the Chalon body kit, but my track tires are Hoosier's: Front 205/45/16 on a 7" BBS wheel, Rears 245/45/16 on an 8" BBS wheel. No problem on the front, the rears just make it.
J P Stein |
Jan 1 2003, 01:37 PM
Chris:
My front set-up in bout the same as yours. My tires rub at full lock on the A arm cross bar (I think). I'll prolly be going to 225 X 50 X 15s up front. It ain't gonna get any better. As to fender clearance....I got a hammer. |
campbellcj |
Jan 1 2003, 09:20 PM
QUOTE(drew365 @ Jan 1 2003, 08:18 AM) This probably won't help you since I have the Chalon body kit, but my track tires are Hoosier's: Front 205/45/16 on a 7" BBS wheel, Rears 245/45/16 on an 8" BBS wheel. No problem on the front, the rears just make it. I didn't know there was a 205/45R16 Hoosier. That would be perfect, slightly taller than a 205/50R15 (about .20"), which is what I want. Somehow I missed it on TireRack.com, or they don't stock that size. All I saw that was close was the 215/40... I'll check again, thanks for the heads-up! Now I just have to track down the local guy who had the cheap 16x7 fuchs. I kinda flaked on picking them up a while back... |
mattillac |
Nov 8 2004, 03:58 PM
robots! Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
can we see some pics? everyone loves pics. (IMG:style_emoticons/default/beerchug.gif)
J P Stein |
Nov 8 2004, 07:37 PM
QUOTE(mattillac @ Nov 8 2004, 01:58 PM) can we see some pics? everyone loves pics. (IMG:style_emoticons/default/beerchug.gif) Hallellujah !!....a FNG that hasn't seen all my pics. I'm settin' here bored outta my skull with a hole in my mouth where 2 teeth usta' be...suppuratin'(no panic, jest blood) & all. Whatcha' want for pics? How bout a rear flare pic? Attached image(s) |
mattillac |
Nov 8 2004, 08:35 PM
QUOTE(J P Stein @ Nov 8 2004, 05:37 PM) QUOTE(mattillac @ Nov 8 2004, 01:58 PM) can we see some pics? everyone loves pics. (IMG:style_emoticons/default/beerchug.gif) Hallellujah !!....a FNG that hasn't seen all my pics. I'm settin' here bored outta my skull with a hole in my mouth where 2 teeth usta' be...suppuratin'(no panic, jest blood) & all. Whatcha' want for pics? How bout a rear flare pic? how 'bout a drifting through a long sweeper pic, tires up in smoke. (IMG:style_emoticons/default/clap56.gif) |
hargray2 |
Nov 8 2004, 08:44 PM
fuh-q Group: Members Posts: 302 Joined: 12-December 03 From: hardeeville,sc Member No.: 1,432 |
What can you put under factory flares? 235/40/17's? how 'bout 45's?
J P Stein |
Nov 8 2004, 09:51 PM
QUOTE(mattillac @ Nov 8 2004, 06:35 PM) how 'bout a drifting through a long sweeper pic, tires up in smoke. (IMG:style_emoticons/default/clap56.gif) Did a skid pad this weekend.....no pics. 100 ft radius I think. Basicly, the car understeers, but with a big lift & back on the hammer, the back end comes out bigtime....holding it there is another problem. I managed it for bout half a turn. Screwed around with it for a while, but mostly it was just wasting perfectly good rubber. Sumthin else to work on this winter. (IMG:style_emoticons/default/biggrin.gif) |
J P Stein |
Nov 8 2004, 10:00 PM
Cones who are about to die, we slaute you.
Not a sweeper , but how to hose up a slalom. Attached image(s) |
drew365 |
Nov 8 2004, 10:17 PM
Talk about waking the dead, this threads almost 2 years old. I was trying to figure out why Chris was still looking for Hoosiers. (IMG:style_emoticons/default/biggrin.gif)
JP, who's going to get their car painted first, you or me? You don't seem to be in any more of a hurry than me. At least I've got the LAPD theme going for me. (IMG:style_emoticons/default/biggrin.gif) Now back to your previouly scheduled thread on tires. |
Trekkor |
Nov 8 2004, 10:39 PM
QUOTE(mattillac @ Nov 8 2004, 02:58 PM) can we see some pics? everyone loves pics. (IMG:style_emoticons/default/beerchug.gif) Pics for you. Vallejo? Just 20 mins away (IMG:style_emoticons/default/clap56.gif) KT Attached image(s) |
Trekkor |
Nov 8 2004, 10:51 PM
Last was Falken Azenis...Awesome tire. Good price, too.
This is the Yokohama A032r soft compound. (IMG:style_emoticons/default/drooley.gif) Oh yes. KT Attached image(s) |
mattillac |
Nov 9 2004, 01:59 AM
QUOTE(J P Stein @ Nov 8 2004, 08:00 PM) Cones who are about to die, we slaute you. Not a sweeper , but how to hose up a slalom. cool! (IMG:style_emoticons/default/rocking nana.gif) |
mattillac |
Nov 9 2004, 02:02 AM
you guys have some nice looking tires! mine look like an old eraser head, dry and cracked. thats what i get for spending all my money on stupid d-jet parts. (IMG:style_emoticons/default/wacko.gif)
Lo-Fi Version | Time is now: 28th April 2024 - 12:34 AM |
