Front lower targa top seal |
partwerks |
Aug 17 2019, 03:39 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Seems hard getting the front lower targa top seal to fit in.
Any thoughts, ideas, or suggestions to help. |
dr914@autoatlanta.com |
Aug 17 2019, 03:48 PM
914 Guru Group: Members Posts: 7,817 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
partwerks |
Aug 17 2019, 03:53 PM
you may need to trim it a bit, has a rectangular notch in the middle, a bit of silicone grease helps as well Seems hard getting the front lower targa top seal to fit in. Any thoughts, ideas, or suggestions to help. I've got it started, since I got that squarish part started in. Since you've probably done lots of these, do I trim the ends square to fit in the corners? With that center piece in the middle, there isn't much more than 1/8" in between, and looks like I am going to have to cut deeper into that notch to allow it to fit down in that narrow groove, or will it prove anything to remove that block, put the seal in, and then reinstall that center block? |
Mikey914 |
Aug 17 2019, 08:06 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We try to cut the notch as close as possible, but you can't add material so we leave any final trimming to the actual install.
The corners are mitered top and bottom to a "point". By the way nice visors |
Mikey914 |
Aug 17 2019, 09:27 PM
By the way the "head" has a flap at the bottom that goes over the textured vinyl upper that the visor clips go into.
It hides the edge by going over it. |
FlacaProductions |
Aug 18 2019, 09:19 AM
Senior Member Group: Members Posts: 1,555 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
@Mikey914 - can you run through this part again - I don't quite understand. I just received your targa seal kit and it's on the short list for install. Just trying to get it in my head before I make the attempt.
By the way the "head" has a flap at the bottom that goes over the textured vinyl upper that the visor clips go into. It hides the edge by going over it. |
partwerks |
Aug 18 2019, 03:21 PM
@Mikey914 - can you run through this part again - I don't quite understand. I just received your targa seal kit and it's on the short list for install. Just trying to get it in my head before I make the attempt. By the way the "head" has a flap at the bottom that goes over the textured vinyl upper that the visor clips go into. It hides the edge by going over it. I think he is talking about that bottom lip you just pull over that texture skin on the moulding so that it hides it. Most likely you will have to carve deeper into that notch so that that square part will go by that center piece in order to fit down. At least that is what I had to do. |
FlacaProductions |
Aug 18 2019, 03:29 PM
Ah - ok. got it.
Mikey914 |
Aug 18 2019, 05:50 PM
Yes beat me to it, but that was what I was trying to articulate.
Mikey914 |
Aug 18 2019, 05:52 PM
I'm emabrassed, but I can clearly see the notch is cut backwards PM me your name and I will have to have another set to you. (IMG:style_emoticons/default/headbang.gif)
Mikey914 |
Aug 19 2019, 03:43 PM
Well duplicated the picture looks like it is cut correctly, just not as deep as we normally cut them.
It should look like this Attached thumbnail(s) |
Mikey914 |
Aug 19 2019, 03:49 PM
This will make it clear as mud
Lo-Fi Version | Time is now: 25th April 2024 - 01:28 PM |
