D-Jet part-load issue goes away when TPS disconnected |
fslick |
Aug 17 2019, 08:02 PM
Newbie Group: Members Posts: 14 Joined: 8-April 12 From: Pittsburgh, PA, USA Member No.: 14,347 Region Association: None |
I have a D-Jet question ('73 1.7).
Symptom is poor running/stumbling when transitioning from idle to part-load. It happens when the engine is both cold and completely warm, but seems to be worse the warmer it is (i.e. full engine temp + hot summer day). Starts and idles just fine hot or cold. Interesting thing is that it's pretty much not noticeable if you VERY SLOWLY go from idle to part-load either with your tippy toes on the gas pedal or just moving the throttle with your hand on the throttle body. Of course you can't drive that way, so if you go from idle to part load normally or quickly, the response is poor and it stumbles but will catch up after about a second (or less). Getting to my question, I took it to a [reputable] shop and they were able to figure out that it runs ok (at least doesn't have this problem) with the TPS disconnected. I am going to take the car back to the shop to have them finish the repair (when they are free) but the engineer in me wants to know why this is a 'fix,' (albeit not the complete FI system). Also does it mean that the TPS is actually the problem? Is this a symptom of it being maladjusted? (All the other usual suspects were checked and seem to be ok (i.e., new vac lines, new fuel lines, good compression and fuel pressure, fuel pump relocated, valves adjusted, checked dizzy, points, swapped ECUs for testing, A/F mix adjusted, replaced MPS, CHT, etc etc). EDIT: I forgot to mention that replacing the TPS (with a used/known good one) has already been done as well. Thanks for reading. |
rjames |
Aug 17 2019, 08:10 PM
I'm made of metal Group: Members Posts: 3,932 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Verify that the TPS is calibrated correctly. Search here or Pelican for the procedure. If that doesn't work, clean the tracks on the TPS board. A pencil eraser worked for me.
If they are too badly worn, new boards are available. Easily done at home. Don't pay a shop to do it unless you like throwing money away. |
fslick |
Aug 17 2019, 08:24 PM
Verify that the TPS is calibrated correctly. Search here or Pelican for the procedure. If that doesn't work, clean the tracks on the TPS board. A pencil eraser worked for me. If they are too badly worn, new boards are available. Sorry, I pulled a cruel trick accidentally and this might not have been included when you sent your reply: EDIT: I forgot to mention that replacing the TPS (with a used/known good one) was already done as well. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:11 PM |
