Crank Bolt, It’s Not M8 x1.25 |
Mblizzard |
Aug 18 2019, 06:28 AM
This not a stock crank. The stock is M8 x1.25. I am sure this is some variation of the AA 78 mm crank but the bolt into nose of crank is clearly not stock.
As near as I can tell it is a M7 1.25. 1.0 is too coarse to start. Anyone know for sure what the threads are on these cranks and where to get the bolt? Type 4 store online has the stock bolt. |
Mark Henry |
Aug 18 2019, 08:21 AM
It should be M8, I'd try chasing it with a tap or a stiff wire galley brush. Likely the tolerances tightened up during heat treating, dirt, or congealed storage coating.
Message the seller, if it's LN they'll likely check one to confirm. |
Lo-Fi Version | Time is now: 19th May 2024 - 05:13 AM |
