Crank Bolt, It’s Not M8 x1.25 |
Mblizzard |
Aug 18 2019, 06:28 AM
This not a stock crank. The stock is M8 x1.25. I am sure this is some variation of the AA 78 mm crank but the bolt into nose of crank is clearly not stock.
As near as I can tell it is a M7 1.25. 1.0 is too coarse to start. Anyone know for sure what the threads are on these cranks and where to get the bolt? Type 4 store online has the stock bolt. |
porschetub |
Aug 20 2019, 12:53 AM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I might be a bit thick but you are talking about the fan hub bolt right?? if so just step up drill size to get to 8mm root diameter of 6.75 and tap to 8 x 1.25 no issue then.
Sharp drills and good taps are the key points here. Mike read my new post on AA performance parts,good luck mate. |
Lo-Fi Version | Time is now: 19th May 2024 - 05:26 AM |
