Water Temp Sender for V8 Conversion, To drive the original oil temp gauge |
DickSteinkamp |
Aug 19 2019, 09:10 AM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
What sender are you non P-motor guys using to use the original oil temp gauge as a water temp gauge? Mine is a Chevy V8 in a 1976 if there is a difference.
I have tried several VDO senders. The closest I can get is their 323-057 (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-20876-1566227463.1.jpg) It is their 0-150C (0-300F) sender. The problem is that it centers the needle at 75C (165F) so at normal operating temps, the needle is about midway to the right of center. Their 0-120C sender exaggerates this even more. Their 0-200C sender centers the needle, but won't give me much warning if I start to over heat. |
DickSteinkamp |
Aug 19 2019, 09:09 PM
In retrospec, I don't think the resistor/potentiometer thing is going to work. That resistance will be there full scale which will prevent the top end of the needle movement from happening.
Thanks Chi-town. I've done a lot of work with Seattle Speedo, but since they (he?) moved to the Spokane area, not the same results. I'll try one of the other two. |
Lo-Fi Version | Time is now: 21st May 2024 - 01:44 PM |
