L-Jet Wire Question, Path of the yellow starter wire current flow... |
jim_hoyland |
Aug 20 2019, 04:06 PM
Get that VIN ? Group: Members Posts: 9,308 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The yellow start wire at the ignition switch goes to the #1 position on the 14 pin relay board in the engine bay; I already have the bypass eliminated under the pass seat.
From here I get confused as to the path from the relay board, the dual relay, and finally the starter. I have a hot-start relay mounted by the starter. Car starts fine, Attached image(s) |
JeffBowlsby |
Aug 20 2019, 07:42 PM
914 Wiring Harnesses Group: Members Posts: 8,515 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Have you studied the schematic Jim? That yellow wire is a circuit between the relay board and double relay.
jim_hoyland |
Aug 20 2019, 07:51 PM
Have you studied the schematic Jim? That yellow wire is a circuit between the relay board and double relay. I did; that thin yellow wire appears to be a “branch” off the main Circuit. Further reading indicates the yellow powers the CSV and fuel pump during starting. I think I better understand it.... |
Lo-Fi Version | Time is now: 24th May 2024 - 10:00 AM |
