Cloudy Fuchs, Yes...I've searched...it's overwhelming. |
FlacaProductions |
Aug 21 2019, 01:17 PM
Senior Member Group: Members Posts: 1,570 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
There are lots of answers here from media blasting to muriatic acid to oven cleaner to Mother's polish....but it's been difficult to wade through and figure out what's specific to my situation so please excuse another "cleaning Fuchs" question....
This is a good example of what mine look like after a good wash. Soap and water with a light Mother's polish on the spokes. See the cloudy bit in the recessed part? Thats' what I want clean and i'd like it in the non-polished/matte finish. I can polish the paddles and the lip but I just can't seem to get rid of the cloudiness. If I need to send them off and get them refinished, that's cool but I'd like to try something myself first. It's a driver so I don't need it to be perfect - just better. |
Aug 21 2019, 01:26 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If some chemical was spilled on the wheels at one time, it might have clouded up the anodizing and the only "cure" is to refinish. I would run them as-is unless you just can't live with it.
sb914 |
Aug 21 2019, 01:34 PM
Surf Guru Group: Members Posts: 4,297 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Probably dog or cat pee.
sixnotfour |
Aug 21 2019, 02:10 PM
914 Wizard Group: Members Posts: 10,419 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
recessed areas are just anodized bare alum,,,that how they came from factory
FlacaProductions |
Aug 21 2019, 02:11 PM
Yup - I just can't get em clean...
dr914@autoatlanta.com |
Aug 21 2019, 02:27 PM
914 Guru Group: Members Posts: 7,833 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Try to rub vaseline on the spokes and let sit overnight
burton73 |
Aug 21 2019, 02:28 PM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Yup - I just can't get em clean... Send them out for refinishing. Fuchsrestoration.com is a great place. I had a set done by Al Read 10 years ago and Jeffrey had a set done my Al Read that looked great and his turnaround was fast. I have had only delays ( slow work) from Al but the work is very good. Your are in LA so Al or Rick are the places to go. Bob B |
FlacaProductions |
Aug 21 2019, 02:49 PM
I'm in LA but the car is in Indiana....but that's why god invented UPS, right?
George, what would that result be? I'm cool with the spokes - it's the recessed area i'm trying to work on.... |
Cairo94507 |
Aug 21 2019, 03:53 PM
Michael Group: Members Posts: 9,725 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
If the recessed area is what you are trying to improve, I might try to tape the high sections off nice and tight, (a good quality tape) and bead blast or soda blast; use some kind of media that will not damage the aluminum. (IMG:style_emoticons/default/beerchug.gif)
horizontally-opposed |
Aug 21 2019, 04:29 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Generally speaking, you want to be careful with what you put on the rough-anodized sections (what's cloudy on your Fuchs), just as you do on the clear anodized sections (the spokes and lips) that look great on your wheels. I'd hate to refinish those wheels unless there was no other choice.
Vaseline may help, or it may not, but my guess is it will only seal in what you've got. My advice would be to try increasingly aggressive cleaners starting with something NOT aggressive and approved by Harvey or Al or anyone else familiar with these wheels. I have had the same problem with the "rough anodized" sections of my Fuchs, and found that once mild soap and water wouldn't do the trick, approved wheel cleaners only got me so far. Trying to remember if Harvey liked Simple Green or not, but I found that Citrus cleaner in VERY limited time bursts and rubbed only with a clean towel succeeded in bringing them back clean without causing any apparent damage. The fact it worked made me wary to the point that I did each wheel one at a time. Wasn't rocket science, but wasn't something I wanted to be distracted from either. Felt a bit risky, and it is. But your wheels are already cloudy, so might be worth a try? Worst case, you send them off for refinishing to one of the three places people seem to like. Good luck! |
Aug 21 2019, 04:54 PM
supposed to remove the staining, but then again the background is rough anyway so if only to remove the stains you can try the vaseline
I'm in LA but the car is in Indiana....but that's why god invented UPS, right? George, what would that result be? I'm cool with the spokes - it's the recessed area i'm trying to work on.... |
bbrock |
Aug 22 2019, 07:48 AM
When I was researching how to restore my Fuchs, the Vasoline thing kept showing up with lots of people reporting good results. Someone on another forum even posted a Porsche tech pub recommending Vasoline to remove stains. My wheels have bigger problems but it seems like it would be worth a shot on yours.
FlacaProductions |
Aug 22 2019, 08:10 AM
Alrighty! Vaseline it is - for the first round, anyway...then I’ll step through a few different cleaners like Pete suggests and we’ll see what happens. It’ll be a bit as I’m not due back in 914-ville for a while...just gathering data.
Lo-Fi Version | Time is now: 4th May 2024 - 12:41 PM |
