Which lifters? |
Which lifters? |
MikeM |
Aug 22 2019, 10:58 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...the cam from my 2 liter is out for re-grind. Assuming it can be done successfully, which new lifters are you guys recommending?
Thanks |
jcd914 |
Aug 22 2019, 02:12 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
If the cam being reground is a stock cam and they are grinding it without having to weld up the lobs, then stock replacement lifters work.
Stock cams are chill cast blanks and do not require heat treating after grinding (if ground correctly) and so a correctly reground cam uses stock lifters. Your cam grinder will be able to tell you what lifters are compatible. Jim |
Lo-Fi Version | Time is now: 17th May 2024 - 08:49 PM |
