Subaru conversion from a Buick swap |
Darrensells |
Aug 23 2019, 03:19 AM
Newbie Group: Members Posts: 4 Joined: 4-August 19 From: San Antonio, TX Member No.: 23,345 Region Association: Southwest Region |
I recently purchased a 1970 914 that was converted to a 3.8 Buick in 1982 but only completed to 90% finished. I am almost finished but the engine has to come out due to timing cover gasket leaking. I am considering changing it all out to a Subaru 6cyl and 5speed Subaru transmission. What donor car should I seek to complete this project? Can I use the engine cradle from the 3.8 Buick? Will it be modifiable? Thanks.
Chi-town |
Aug 23 2019, 01:46 PM
The mounts are in a completely different area and can't be added to the V6/V8 style mount.
Currently only Renegade is making a bolt in cradle at $1k each |
Darrensells |
Aug 23 2019, 01:51 PM
The mounts are in a completely different area and can't be added to the V6/V8 style mount. Currently only Renegade is making a bolt in cradle at $1k each My mechanic says since so much has been invested into the Buick 3.8 setup, I should keep it with a 3.8 GM. He makes some good points. It would be cheaper. Just need a newer fuel injected engine. The 77 Regal engine does not have a lot of power and it is carb. |
Chris H. |
Aug 23 2019, 03:11 PM
Senior Member Group: Members Posts: 4,028 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
The mounts are in a completely different area and can't be added to the V6/V8 style mount. Currently only Renegade is making a bolt in cradle at $1k each My mechanic says since so much has been invested into the Buick 3.8 setup, I should keep it with a 3.8 GM. He makes some good points. It would be cheaper. Just need a newer fuel injected engine. The 77 Regal engine does not have a lot of power and it is carb. And the Renegade cradle is designed to work with the 901 trans I think...you can't use the Subaru trans unless they have updated it. There are a couple of great 3.8 Buick V6 cars on the board...check Phoenix-MN and pjhaun. There was also a white 4.3 Vortec floating around a LONG time ago that was very nice. Not a bad idea to stick with the Buick and just find a higher performance engine. Much easier than starting over. The challenge is that it's nearly impossible to find a 5 speed EZ30D Subaru donor, in fact I have never seen one. This means you have to source the trans from one car and the engine/wiring harness/other stuff from another. And the wiring....oh the wiring.... (IMG:style_emoticons/default/headbang.gif) . If you were starting with a bare shell that would be fine, but you have an almost completed swap already. Totally up to you though...the EZ30D is a VERY good engine and the Subaru trans is a significant upgrade. |
Lo-Fi Version | Time is now: 28th April 2024 - 08:56 AM |
