Subaru conversion from a Buick swap |
Darrensells |
Aug 23 2019, 03:19 AM
Newbie Group: Members Posts: 4 Joined: 4-August 19 From: San Antonio, TX Member No.: 23,345 Region Association: Southwest Region |
I recently purchased a 1970 914 that was converted to a 3.8 Buick in 1982 but only completed to 90% finished. I am almost finished but the engine has to come out due to timing cover gasket leaking. I am considering changing it all out to a Subaru 6cyl and 5speed Subaru transmission. What donor car should I seek to complete this project? Can I use the engine cradle from the 3.8 Buick? Will it be modifiable? Thanks.
914forme |
Aug 25 2019, 11:40 AM
3.8 GM engine is a fine engine, I would go EFI and supercharged if you want to make something odd and interesting. Stock it is 240HP, a PCM and a pulley swap and you are getting closer to 270 if you think you need it.
240 is a pretty decent number in a 914 Engine is darn near bullet proof, except the latter ones that switched to a plastic water inlet manifold. But most of them have been fixed by now. |
Lo-Fi Version | Time is now: 28th April 2024 - 05:49 AM |
