> Project Thread Fredriks GT build, GT-build, rustoration, making parts and nerding out.
GTSandberg
post Aug 23 2019, 08:08 AM
Region Association: Europe
I am starting this thread "in medias res" with the car as it is today.
Then I will post a confusing mix of past and present, showing the project updates and process. Promise to nerd out on the details. (IMG:style_emoticons/default/welder.gif) .
5 Pages V  1 2 3 > »
Replies(1 - 19)
mb911
post Aug 23 2019, 08:29 AM
Will be watching.
Retroracer
post Aug 23 2019, 12:59 PM
Ditto. Keep the posts coming!
- Tony
Cairo94507
post Aug 23 2019, 05:30 PM
Michael
Love the build threads. (IMG:style_emoticons/default/beerchug.gif)
tygaboy
post Aug 23 2019, 08:07 PM
Great looking with the Minilites/Fuchs mix! And it looks like there's been a lot of metal work done. I'd love to see details on all that, if you have it.
Keep the posts coming and best of luck with your build. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
GTSandberg
post Aug 26 2019, 07:55 AM
Ok, so the hell hole, turns out it was not rust free.. Hælveteshøl it would be called in Norwegian btw.
It seemed to be solid, but some closer investigation revealed sloppy previous rust repairs. (x2)
Not one, but two layers of new metal without removing the original disaster area.
After removing the old crap I started fabricating the new parts. It is not really very complex geometry, and only two areas needed "special tooling".
This is the bottom of the hole, and the flange towards the side.
And the shelf.
I would not call it hell, but more like tedious and annoying-hole.
Dion
post Aug 26 2019, 08:50 AM
RN
Fantastic work. Obviously not your first rodeo.
I’m tuned in. I’ll have to consult with my Norwegian Elghund to
interpret for me. (IMG:style_emoticons/default/beerchug.gif)
Literati914
post Aug 26 2019, 10:00 AM
QUOTE(GTSandberg @ Aug 26 2019, 08:55 AM) *
That's about the cleanest looking HH repair I've seen, great job! Did you put a drain hole down towards the bottom of it, as stock?
GTSandberg
post Aug 27 2019, 06:59 AM
QUOTE(Literati914 @ Aug 26 2019, 04:00 PM) *
Thank you! Also a good point, The drain hole is in place, important to make it the lowest point, as indicated by the two red lines. As seen in the picture small parts tend to gather in the HH, neat.
GTSandberg
post Aug 27 2019, 07:01 AM
QUOTE(Dion @ Aug 26 2019, 02:50 PM) *
Thank you, say hello to the Elghund! (IMG:style_emoticons/default/bye1.gif)
post Aug 27 2019, 07:12 AM
914-6 GT in waiting
Cairo94507
post Aug 27 2019, 07:25 AM
Michael
Beautiful repair. (IMG:style_emoticons/default/beerchug.gif)
GTSandberg
post Aug 28 2019, 03:22 AM
Appreciate all feedback (IMG:style_emoticons/default/smile.gif)
Here are two pictures of the car before I started cutting in it. Quite complete, but not pretty. Solid but a bit rough..
GTSandberg
post Aug 29 2019, 07:55 AM
The front fenders has been a lot of work, 914s are not very common in Norway and spare parts are not easy to come by. There were some previous rust repairs that needed to be redone.
The gap between the fender and the part infront of the windshield was welded together, and was not straight. Here I am making the two parts to weld in.
There was also something odd with the door gap..
In progress..
Welded in place, and doing some body soldering with lead
More or less finished, how many layers of paint can you see? (IMG:style_emoticons/default/biggrin.gif)
GTSandberg
post Sep 5 2019, 08:11 AM
Here is a good example of doing things the hard way.. The goal is to modify the sheet metal structure around the jack mounts to make room for the GT-oil lines. To do this modification I would recomend the following. Buy the replacement sheet metal part, cut and weld. I choose to make a stamping tool (IMG:style_emoticons/default/screwy.gif)
One of the failed attemts and the male tool.
One of the almost good parts after some work, and the female tool.
Welding in the fabricated part.
Test fitting my brand new paper oil lines.
bbrock
post Sep 5 2019, 08:24 AM
I'm just catching up on your build thread. Loving your fabrication work! Keep 'em coming. (IMG:style_emoticons/default/aktion035.gif)
post Sep 5 2019, 08:35 AM
GTSandberg
post Sep 5 2019, 01:16 PM
QUOTE(bbrock @ Sep 5 2019, 02:24 PM) *
Thanks! I will keep posting (IMG:style_emoticons/default/type.gif)
Your build thread has been a true inspiration to me btw!
defianty
post Sep 5 2019, 01:20 PM
Nice work, look forward to seeing more.
mb911
post Sep 5 2019, 02:15 PM
Just a note as I have had made and sold 38 sets of GT hard lines the indent really is not required.. I had no issues fitting mine personally ..
5 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 3rd July 2025 - 12:22 AM
