Double Relay After Carb Conversion, Is there any use for the Double Relay After Carb Conversion? |
downrange |
Aug 23 2019, 10:51 AM
Newbie Group: Members Posts: 22 Joined: 1-January 18 From: Pennsylvania Member No.: 21,747 Region Association: MidAtlantic Region |
I am converting L Jetronic fuel Injection to single carb with electric choke. Is there any use for the double relay?
JeffBowlsby |
Aug 23 2019, 09:10 PM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Several skilled and experienced 914 owners have spoken here, not in an effort to be critical but recognize that in this community, many are willing to give you the benefit of their wisdom from lessons learned (mistakes made) by those who have done what you are intending to do now. Please do not take their recommendations lightly. What you have not mentioned is the purpose and expectations you hope to achieve from the single carb, but you don't need ours or anyone's approval.
That said, the L-Jet ignition harness will need significant modification to use with carbs, basically a full rebuild and reconfiguration. A D-Jet ignition harness is the plug N play solution for carbs. |
Lo-Fi Version | Time is now: 17th May 2024 - 01:35 AM |
