> BOSCH Distributor Part Numbers, any experts out there??
malcolm2
post Aug 24 2019, 11:37 AM
what is the difference in mine vs a loaner..
JFU4 vs JFUD4
bosch 0 231 176 048 vs 0 231 181 009
VW 021 90-5 205 A-B vs 022 905 205 AA
Mine is from a 75 1.8. Came with the car, no idea if it is right or not. Not sure about the vs one. both have vacuum advance and electronic modules... mine is hot spark vs Petronics.
I got a loaner to try cause my idle has been erratic and my retard vacuum is broken... hose pulled and plugged did not good.
Want to install the loaner, but it IS DIFFERENT. question is how different? or maybe a better question is, will it work in my L-Jet 1911?
dr914@autoatlanta.com
post Aug 24 2019, 12:06 PM
will for the most part be interchangeable. The AA was the earlier version 1.8 with vacuum advance retard, the ab was the later one with vacuum retard only
As to the specifics, the aa probably had a different advance curve than the ab, and actually wore a different rev limiting rotor than the ab.
Subtile changes for emissions
QUOTE(malcolm2 @ Aug 24 2019, 10:37 AM) *
JFU4 vs JFUD4
Want to install the loan, but it IS DIFFERENT. question is how different? or maybe a better question is, will it work in my L-Jet 1911?
JFJ914
post Aug 24 2019, 12:40 PM
Doc's right. If we could go down to the corner store and buy the correct distributor we would. But we can't, so we use what we have. It usually works. My '74 1.8 came with a 1.7 D-Jet dist along with a 75-76 2.0 D-Jet Fuel injection system. Runs fine.
malcolm2
post Aug 24 2019, 02:40 PM
QUOTE(JFJ914 @ Aug 24 2019, 01:40 PM) *
So, as i figured. “put it in, see what happens.”?
JFJ914
post Aug 24 2019, 03:01 PM
QUOTE(malcolm2 @ Aug 24 2019, 04:40 PM) *
Absolutely! It's time to come to the dark side.
malcolm2
post Aug 24 2019, 06:02 PM
Gonna lube it up with my sili kroil and let it sit overnight. Install, timing, and test drive on Sunday.
malcolm2
post Aug 24 2019, 06:44 PM
So if i want to lube this loaner, how do i get the plates out?
914_7T3
post Aug 25 2019, 01:59 PM
Below is a link to a comprehensive list of part numbers and compatibility for your reference.
https://members.rennlist.com/pbanders/DJetParts.htm
malcolm2
post Aug 25 2019, 07:15 PM
Good stuff but i am dealing with 1.8 L-Jet stuff. Anders is the D-Jet master.
914_7T3
post Aug 25 2019, 09:46 PM
QUOTE(malcolm2 @ Aug 25 2019, 06:15 PM) *
Missed that part............................ (IMG:style_emoticons/default/confused24.gif)
- Lo-Fi Version Time is now: 16th March 2026 - 09:51 PM
