BOSCH Distributor Part Numbers, any experts out there?? |
malcolm2 |
Aug 24 2019, 11:37 AM
what is the difference in mine vs a loaner..
JFU4 vs JFUD4 bosch 0 231 176 048 vs 0 231 181 009 VW 021 90-5 205 A-B vs 022 905 205 AA Mine is from a 75 1.8. Came with the car, no idea if it is right or not. Not sure about the vs one. both have vacuum advance and electronic modules... mine is hot spark vs Petronics. I got a loaner to try cause my idle has been erratic and my retard vacuum is broken... hose pulled and plugged did not good. Want to install the loaner, but it IS DIFFERENT. question is how different? or maybe a better question is, will it work in my L-Jet 1911? |
dr914@autoatlanta.com |
Aug 24 2019, 12:06 PM
914 Guru Group: Members Posts: 7,856 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
will for the most part be interchangeable. The AA was the earlier version 1.8 with vacuum advance retard, the ab was the later one with vacuum retard only
As to the specifics, the aa probably had a different advance curve than the ab, and actually wore a different rev limiting rotor than the ab. Subtile changes for emissions what is the difference in mine vs a loaner.. JFU4 vs JFUD4 bosch 0 231 176 048 vs 0 231 181 009 VW 021 90-5 205 A-B vs 022 905 205 AA Mine is from a 75 1.8. Came with the car, no idea if it is right or not. Not sure about the vs one. both have vacuum advance and electronic modules... mine is hot spark vs Petronics. I got a loaner to try cause my idle has been erratic and my retard vacuum is broken... hose pulled and plugged did not good. Want to install the loan, but it IS DIFFERENT. question is how different? or maybe a better question is, will it work in my L-Jet 1911? |
Lo-Fi Version | Time is now: 14th May 2024 - 11:08 AM |
