BOSCH Distributor Part Numbers, any experts out there?? |
malcolm2 |
Aug 24 2019, 11:37 AM
what is the difference in mine vs a loaner..
JFU4 vs JFUD4 bosch 0 231 176 048 vs 0 231 181 009 VW 021 90-5 205 A-B vs 022 905 205 AA Mine is from a 75 1.8. Came with the car, no idea if it is right or not. Not sure about the vs one. both have vacuum advance and electronic modules... mine is hot spark vs Petronics. I got a loaner to try cause my idle has been erratic and my retard vacuum is broken... hose pulled and plugged did not good. Want to install the loaner, but it IS DIFFERENT. question is how different? or maybe a better question is, will it work in my L-Jet 1911? |
JFJ914 |
Aug 24 2019, 12:40 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Doc's right. If we could go down to the corner store and buy the correct distributor we would. But we can't, so we use what we have. It usually works. My '74 1.8 came with a 1.7 D-Jet dist along with a 75-76 2.0 D-Jet Fuel injection system. Runs fine.
malcolm2 |
Aug 24 2019, 02:40 PM
Doc's right. If we could go down to the corner store and buy the correct distributor we would. But we can't, so we use what we have. It usually works. My '74 1.8 came with a 1.7 D-Jet dist along with a 75-76 2.0 D-Jet Fuel injection system. Runs fine. So, as i figured. “put it in, see what happens.”? |
Lo-Fi Version | Time is now: 14th May 2024 - 09:53 AM |
