What kind of Power Improvements did you see after Conversions? |
9144me2enjoy |
Aug 24 2019, 05:21 PM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
There has been all kinds of engine swaps into the Base 914s (Porsche Aircooled 6 cyls-2.0L 2.2L 2.4L 2.7L 3.0L 3.2L 3.6L) along with a large range of Subaru Conversions and LS1 engines, SBC, any other conversions, along with 2056 builds etc. I’m sure a lot of people besides myself would like to see some performance specs after these conversions were completed (0-60mph 0-100mph, 1/4 mile, roll on performance) along with transmission changes and estimated cost for conversion.
Example: Upgraded to 2056cc build (Fats Performance), 125-130hp, dual 40 carbs, cam etc., headers, stock 901 side shift trans. With Rennshift Shifter, 911 suspension conversion. 0-60 6.5 seconds. 1/4 mile about 90 mph. Cost for drivetrain including trans rebuilt approx $10,000.00 in 2015. |
thelogo |
Aug 24 2019, 06:08 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Big /4
5k dollar engine (IMG:style_emoticons/default/piratenanner.gif) Webbers headers super unleaded gas Car is alot faster /fun 'er Still just as light (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/smoke.gif) /6 guys are crazy $ I'll be saving for a 993 or nsx (IMG:style_emoticons/default/pray.gif) |
80’s old school |
Aug 24 2019, 06:09 PM
Member Group: Members Posts: 79 Joined: 26-March 19 From: California Member No.: 22,994 Region Association: Southern California |
(IMG:style_emoticons/default/popcorn[1].gif) I’m interested too!
Aug 24 2019, 06:27 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
2 - 3.2 conversions and one 3.3 suby conversion. Lots of time, money and fun. Faster than stock. (IMG:style_emoticons/default/biggrin.gif)
9144me2enjoy |
Aug 24 2019, 07:45 PM
Mepstein how do you compare the 3.2 vs the Suby 3.3 conversions?
80’s old school |
Aug 24 2019, 08:09 PM
I took a 1.7 with Weber 40’s out.
Put in a 1.8 with 96mm AA flat top pistons (1911cc). No cylinder to case shims and no cylinder to head shims (to create max compression available without machining mods). Same 40 Weber’s. Then added MSDS header. Difference was night and day! Very noticeable upgrade. I don’t have any 0-60, 1/4 mile runs, etc., but a nice “shot in the arm” |
Aug 24 2019, 08:36 PM
Mepstein how do you compare the 3.2 vs the Suby 3.3 conversions? Suby conversion isn't running yet. Cost wise, the suby engine (eg33-220hp) was $500 and the 5mt trans $200. A decent 3.2 is $12K and a modified 915 trans ~$7-10K. So there's that to consider... |
9144me2enjoy |
Aug 24 2019, 08:52 PM
Impressive builds
Aug 24 2019, 09:09 PM
Resident German Group: Admin Posts: 41,581 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
0-60 < 4s ... (IMG:style_emoticons/default/burnout.gif)
worn |
Aug 24 2019, 09:25 PM
can't remember Group: Members Posts: 3,127 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
2 - 3.2 conversions and one 3.3 suby conversion. Lots of time, money and fun. Faster than stock. (IMG:style_emoticons/default/biggrin.gif) Lots more fun with the 3.2. I mean, it is great. Better distance car too, cause i also went for taller gears in 4th and 5th. Estimate 0-60 in the 5 second range. Not bad, but not so stupid fast you have no place to use it off track. I also feel that my 2056 build, though a bit of a handful to tune left me with a bit more sparkle to the engine. But then, the comparison may have been a bit worn out. |
Chris914n6 |
Aug 24 2019, 09:35 PM
Jackstands are my life. Group: Members Posts: 3,287 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
My Nissan 3.0L v6 is 190hp & 205tq stock, with a rebuilt 914 trans & tall 5th, does 0-60 in 5.x in just 2nd gear @6800rpm. Plus it makes more low end tq than a 3L Porsche -6. Plus it has a bolt on AC compressor (IMG:style_emoticons/default/smile.gif)
Eng/harness/ecu was $1600 w/ 15k miles back in 97 Kennedy adapter, 300hp clutch $700 Cooling ~$400 Engine crossbar ~$100 Exhaust, cat, 911 banana muffler $200 Other stuff ~$200 Plus 180lb springs, 911 susp, Boxster 16" wheels. If were to do it today... 290hp & 270tq, 0-60 in 4.0s Nissan 3.5L v6 mutt ~$600+ MS3pro & related $1400 Cooling ~$300 Crossbar ~$100 Dual exhaust, headers ~ $300 Fuel pump $90 And I'm working on a WRX trans adapter. If that ever gets boring, +turbo = 400whp (IMG:style_emoticons/default/bye1.gif) |
pploco |
Aug 24 2019, 09:40 PM
Chief Toilet Flusher Group: Members Posts: 105 Joined: 15-June 18 From: boise, idaho Member No.: 22,225 Region Association: Rocky Mountains |
It’s not quite the same, but I had a 2.0 legacy turbo in a 63 baja bug that was about 300hp to the wheels. I ran a 1/4 mile in the low 12s. And that was with truck tires and a bus transmission. The car weighed about 1900 lbs. I bet with a well sorted turbo suby conversion and a modern trans in the 914, a decent driver could get down into the low 11s.
Doing a bit of napkin math, I figure my 914 will have the same power to weight ratio as a modern GT3. |
9144me2enjoy |
Aug 24 2019, 09:52 PM
This is great feedback, especially for forum members who have had a dream to build their 914s to obtain more power on or off the track! This gives us all hope to rekindle the fire within these amazing machines! Thanks
ConeDodger |
Aug 24 2019, 10:06 PM
Apex killer! Group: Members Posts: 23,543 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Hasn’t been mentioned but I’d drive my 3.2 conversion anywhere. I never had that confidence with the 4 cylinder.
Attached thumbnail(s) |
Andyrew |
Aug 24 2019, 11:25 PM
Well I have two conversions under my belt so let me throw my input out there..
Base engine was a 2.0 with FI that ran poorly. I had 75whp. Next I did a $3k rebuild and SBC V8 conversion. This was done on a 16 year olds budget working at Taco Bell.... Mild build, made 240whp and 290wtq. Too much torque for the chassis in relationship to the power. Biggest issue was keeping it cool. I loved the V8 sound and played around with the V8 for about 10 years. I never made it reliable enough for me to really drive it. So that lead to my next conversion. After daily driving an Audi A4 that I modified with a big turbo I really liked the engine a Lot. It had great MPG and a fantastic powerband. So after doing some research I decided to make the 914 something it wasn't. A potential daily car. And with that I wanted all the comforts as well as an engine that could be driven easily as well as something that could be driven both in spirit and anger. That led me to do an Audi 1.8turbo swap. I've never fully built a motor so I said let's do it and out way more money into the build than I needed. I could have done this for about 4k comfortably but I spent about 10k. You can read more about it in my signature. Anyways numbers. On low boost it's 250whp. On medium low boost it's 285whp. Keep in mind the setup is about 150lbs lighter than the V8. I will say that I still haven't pumped it up yet as I've been going through a lot of teething issues, but over the next few years I'll keep pumping the boost up, I should be able to get 400whp as is with good gas. If I put cams and an intake manifold on it that number should be able to grow to 500whp. Is it fast? You bet. Faster than the V8? Yes, but only over 4k. But probably the biggest thing is it feels really analog. The turbo noises and engine sounds are extremely apparent and so distinct. The turbo and associated bits itself has about 10 district sounds that I can pick up. One of the reasons for me to go with such a small motor and big turbo was so that I can run low boost and it be quick, take it in the canyons and be pretty comfortable and safe. Then when I really wanted to GO I can turn up the boost and be right there with the big boys. No drag times or whatnot. I do have an autox vid. Traction is a big issue on a dirty low speed autox, so I'm constantly on and off the throttle. This is boost on the lowest setting. 7psi. Note, prepare for turbo noises.. https://www.youtube.com/watch?v=JXLC59RiHe8 |
mb911 |
Aug 25 2019, 07:22 AM
914 Guru Group: Members Posts: 6,748 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Sound and feel is one of the biggest things that most people notice 1st about a -6 conversion.. And of course power..
Coondog |
Aug 25 2019, 07:52 AM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Here’s the best comparison of a 2.0 vs a 3.2
Cairo94507 |
Aug 25 2019, 09:34 AM
Michael Group: Members Posts: 9,650 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Andrew - That was a great video. Your car sounded and performed quite nicely. (IMG:style_emoticons/default/beerchug.gif)
Carl La Fong |
Aug 25 2019, 10:29 AM
Member Group: Retired Members Posts: 137 Joined: 27-March 19 From: west Member No.: 23,000 Region Association: None |
I currently drive a 2.2 liter type IV that produced 147hp on the dyno. A really fun car to drive.$ I used to have a 3.2 liter that produced 235hp. A really REALLY fun car to drive. $$$$
80’s old school |
Aug 25 2019, 10:39 AM
Lo-Fi Version | Time is now: 28th March 2024 - 06:50 PM |
