Axle angle |
Axle angle |
partwerks |
Sep 8 2019, 05:21 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
euro911 |
Sep 25 2019, 07:51 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,848 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Can you shorten the upright sections of the trans mount to gain a couple inches of upward movement?
partwerks |
Sep 27 2019, 09:07 PM
euro911 |
Sep 28 2019, 03:59 AM
Can you shorten the upright sections of the trans mount to gain a couple inches of upward movement Are you saying to cut the flat bars loose on top of the main bracket, and jack the trans up higher, and then reweld the flat bars?I'm also wondering if a different rubber mount could be fabricated, and located UNDER the 'flat bars' (instead of above)? ... looks like you could gain an inch or so there (IMG:style_emoticons/default/idea.gif) If you're planning on raising the rear suspension (as you mentioned earlier) with taller springs, you'll gain even more equality between the center-line of the trans output shafts and the center-line at the wheel hubs. That should straighten out the axle angles enough to cause a lot less wear & tear on the CVs. |
partwerks |
Sep 28 2019, 08:11 AM
Can you shorten the upright sections of the trans mount to gain a couple inches of upward movement Are you saying to cut the flat bars loose on top of the main bracket, and jack the trans up higher, and then reweld the flat bars?I'm also wondering if a different rubber mount could be fabricated, and located UNDER the 'flat bars' (instead of above)? ... looks like you could gain an inch or so there (IMG:style_emoticons/default/idea.gif) If you're planning on raising the rear suspension (as you mentioned earlier) with taller springs, you'll gain even more equality between the center-line of the trans output shafts and the center-line at the wheel hubs. That should straighten out the axle angles enough to cause a lot less wear & tear on the CVs. Not sure how heavy of springs are in there, but wonder how heavy I need for the LS3 engine, 180lb? Sounds like 180lb are shorter than stock? https://forums.pelicanparts.com/porsche-914...ed-details.html I have the mounting plates on top now. I'm not sure how I could move the trans forward any? |
euro911 |
Sep 28 2019, 11:50 AM
Not sure how heavy of springs are in there, but wonder how heavy I need for the LS3 engine, 180lb? ... (IMG:style_emoticons/default/confused24.gif) ... Definitely a question for the V8 guys. Sounds like 180lb are shorter than stock? https://forums.pelicanparts.com/porsche-914...ed-details.html ... I believe so. That's why I suggested measuring your existing springs. I have the mounting plates on top now ... Good. I'm not sure how I could move the trans forward any? ... Sorry, can't help you there. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 6th May 2024 - 09:18 AM |
