F/S 1974 914 2.0, $10,750 / Offers - SOLD |
HarveyH |
Sep 9 2019, 12:20 PM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
Not a show car, but a nice Sunday Driver. I’ve never driven it more than 500 miles in a year, and usually much less. Probably less than 5,000 miles since I bought it.
harveyhoover@comcast.net 610-269-1075 – Leave Message * 2056 with cam and Webers * 2 Liter heads * Bilstein shocks and strut inserts * 914-6 rear springs (80 Lbs.???) * 19mm front sway bar with factory linkage * Stock 16mm rear sway bar * New (4/2019) Rear main Seal and Flywheel / Clutch / Pressure Plate / Throw Out Bearing assembly * Recent (mileage wise) engine rebuild * Mahle alloy wheels (5) * Longitudinals and jack posts replaced * Crane Hi-6 multi-spark box with PS91 coil and Pertronix point replacement * Recent new alternator and solid state regulator * Relay board cleaned and all connection points soldered * SSI heat exchangers * LED running and instrument lights * Bronze pedal cluster bushings * Recently repaired odometer shows 82900 but real mileage unknown (Operated intermittently when I bought the car) Also Included: * Restoration Design panels for engine shelf repair and new battery shelf * Parts accumulation for under trunk external oil cooler * Parts accumulation for deep oil sump * Various parts for original fuel injection system. Brain, manifolds, throttle body, injectors with wiring harness, etc. * Original Porsche crest steering wheel (Aftermarket wrapping, don’t know what’s under it) * Repro 916 front bumper * Weltmeister short shift kit (Tried it, didn’t like it.) * Miscellaneous seals, gaskets, ignition parts, etc. * 20+ years of 914 related magazine clippings * Haynes and Clymer Workshop Manuals * HP and Bob Tomlinson Weber Manuals * Other 914 related books and literature |
Lo-Fi Version | Time is now: 24th April 2024 - 07:07 PM |
