Newbie hoser scammer pics, The 914 has arrived |
Ratrod87 |
Sep 9 2019, 08:35 PM
Member Group: Members Posts: 69 Joined: 4-September 19 From: Ft Mitchell Alabama Member No.: 23,429 Region Association: None |
Hello everyone my name is Jerry also known to some as (newbie hoser scammer ) I recently within the past few days purchased our first 914 . I immediately fell in love with the car at first sight along with my two sons age 9 and 18. I was very nervous about purchasing a car that I knew nothing about, with that said the car arrived today and I had already prepared myself for disappointment because in the past every time I bought a project car it turns out to be way worse than I thought. I'm pleased to say this car did not disappoint me. I immediately started looking the car over expecting to find rotted floors and rockers , quarters or something. I pulled the trunk carpets out and no visible rust. I poked around with a screw driver and nothing. I scraped under coating off in the wheel well and corners thinking I'll definitely find rust there but nothing. I haven't pulled the rocker covers off yet so there is still a chance. The only place with rust was below the battery which didn't even look that bad, the dreaded hell hole was the only spot I could find so far and didn't look as bad as I thought.
porschetub |
Sep 10 2019, 12:40 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
As mentioned don't lift on there,clean car but looks like a battery acid victim...pretty normal.
The carb you have is a good carb but not on a T4,you have very long intake runners and no pre-heat,they are just ok but no better than much really. If you have a bus motor you need to supply engine number so folks know what you have,I strongly suspect it may be unsuited to carbs and could be a D-jet or later L-jet, don't think carbs on 2.0 motors were around in that era in the US but certainly in Europe. |
Lo-Fi Version | Time is now: 26th April 2024 - 07:53 PM |
