Newbie hoser scammer pics, The 914 has arrived |
Ratrod87 |
Sep 9 2019, 08:35 PM
Member Group: Members Posts: 69 Joined: 4-September 19 From: Ft Mitchell Alabama Member No.: 23,429 Region Association: None |
Hello everyone my name is Jerry also known to some as (newbie hoser scammer ) I recently within the past few days purchased our first 914 . I immediately fell in love with the car at first sight along with my two sons age 9 and 18. I was very nervous about purchasing a car that I knew nothing about, with that said the car arrived today and I had already prepared myself for disappointment because in the past every time I bought a project car it turns out to be way worse than I thought. I'm pleased to say this car did not disappoint me. I immediately started looking the car over expecting to find rotted floors and rockers , quarters or something. I pulled the trunk carpets out and no visible rust. I poked around with a screw driver and nothing. I scraped under coating off in the wheel well and corners thinking I'll definitely find rust there but nothing. I haven't pulled the rocker covers off yet so there is still a chance. The only place with rust was below the battery which didn't even look that bad, the dreaded hell hole was the only spot I could find so far and didn't look as bad as I thought.
ClayPerrine |
Sep 10 2019, 07:55 AM
Life's been good to me so far..... Group: Admin Posts: 15,392 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You have a great starting point. Most people find lots more rust than that. Build a 2056 with D-Jet and install it. That is the most bang for the buck in the Type IV builds. The transmission probably sheared the roll pin on the side shifter console. It happened to us years ago. Easy fix, but you have to drain the gear oil and pull the shift console. Suspension upgrades would be a set of sway bars, new springs and shocks. and some wider tires. The rest of the car looks great. Wonderful find! |
Ratrod87 |
Sep 10 2019, 08:04 AM
(IMG:style_emoticons/default/welcome.png) You have a great starting point. Most people find lots more rust than that. Build a 2056 with D-Jet and install it. That is the most bang for the buck in the Type IV builds. The transmission probably sheared the roll pin on the side shifter console. It happened to us years ago. Easy fix, but you have to drain the gear oil and pull the shift console. Suspension upgrades would be a set of sway bars, new springs and shocks. and some wider tires. The rest of the car looks great. Wonderful find! What's your thoughts on the steel fender flares, I want to keep the car as original as possible but my son likes the flares and sportier look. Would doing that take away from the car? |
ClayPerrine |
Sep 10 2019, 08:31 AM
(IMG:style_emoticons/default/welcome.png) You have a great starting point. Most people find lots more rust than that. Build a 2056 with D-Jet and install it. That is the most bang for the buck in the Type IV builds. The transmission probably sheared the roll pin on the side shifter console. It happened to us years ago. Easy fix, but you have to drain the gear oil and pull the shift console. Suspension upgrades would be a set of sway bars, new springs and shocks. and some wider tires. The rest of the car looks great. Wonderful find! What's your thoughts on the steel fender flares, I want to keep the car as original as possible but my son likes the flares and sportier look. Would doing that take away from the car? What I always say is "You have to live with the car. Do what you like to it." I have flares on my 914-6 conversion, my wife doesn't have them on her 914 1.8L. Our six is original, and is not flared. If you add the flares, you need wider tires and rims. That means bigger brakes. And that means a 5 lug conversion. Be careful... its a slippery slope. I should know...... (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 19th April 2024 - 06:36 AM |
