Newbie hoser scammer pics, The 914 has arrived |
Ratrod87 |
Sep 9 2019, 08:35 PM
Member Group: Members Posts: 69 Joined: 4-September 19 From: Ft Mitchell Alabama Member No.: 23,429 Region Association: None |
Hello everyone my name is Jerry also known to some as (newbie hoser scammer ) I recently within the past few days purchased our first 914 . I immediately fell in love with the car at first sight along with my two sons age 9 and 18. I was very nervous about purchasing a car that I knew nothing about, with that said the car arrived today and I had already prepared myself for disappointment because in the past every time I bought a project car it turns out to be way worse than I thought. I'm pleased to say this car did not disappoint me. I immediately started looking the car over expecting to find rotted floors and rockers , quarters or something. I pulled the trunk carpets out and no visible rust. I poked around with a screw driver and nothing. I scraped under coating off in the wheel well and corners thinking I'll definitely find rust there but nothing. I haven't pulled the rocker covers off yet so there is still a chance. The only place with rust was below the battery which didn't even look that bad, the dreaded hell hole was the only spot I could find so far and didn't look as bad as I thought.
Rob-O |
Sep 10 2019, 07:13 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
I think all of the above is sound advice.
I love that color (looks like Tangerine). If it were me I’d get The car operational first and then make a list of projects to tackle. I agree with Clay that the roll pin inside the trans is your most likely culprit. An easy job. Pull the long shift rod at the firewall and at the transmission. Drain the transmission. But make sure you can loosen the top trans fill plug before you loosen and drain the trans fluid. More than a few of us have pulled the bottom plug on the trans to drain it only to realize that they could t get the top plug off, leaving them no way to refill the transmission with fluid. Once the transmission is drained pull the shift console. I believe it’s just two 10mm or two 13mm bolts holding it in. The shift rod on that console that goes into the transmission has a ‘finger’ on it that engages the gears. The finger is held onto that shift rod inside the transmission with a small roll pin that goes through the rod and the finger. If it’s all in one piece you can tilt the whole console to get it out. If the shift finger has sheared the pin the console will come out pretty easily and the finger should fall out after it. Hopefully the pin parts fall out, too. Inspect and see what’s needed. There are some seals to replace while you’re in there to help prevent leaks. I’d also check the bushings that the long shift rod rides in on the shifter console and replace. Cheap part but helps shift feel. Also there are bushings at the front of the shift rod. I’m assuming that since you have a side shifter trans that the front of the shift rod has the late style shift knuckle. That can be disassembled and the bushings replaces (search the site of how to do this without breaking the aluminum cage). Then go for a short drive...you’ll get a feel for what needs to get repaired. But get those rusted areas repaired quickly. Lots of help here and probably several people in your area here on the board willing to lend a hand. On a side note the 914 is incredibly blessed on the amount of parts that are available. Very, very few parts are unavailable. For instance you asked about the rubber bumper tops being available. The guy that replied that yes they were? Yeah, he’s the guy that makes them...and about a million other parts for the 914. You can visit his site (www.914rubber.com) but prepare your wallet to be decimated in short order. |
Ratrod87 |
Sep 10 2019, 09:34 PM
I think all of the above is sound advice. I love that color (looks like Tangerine). If it were me I’d get The car operational first and then make a list of projects to tackle. I agree with Clay that the roll pin inside the trans is your most likely culprit. An easy job. Pull the long shift rod at the firewall and at the transmission. Drain the transmission. But make sure you can loosen the top trans fill plug before you loosen and drain the trans fluid. More than a few of us have pulled the bottom plug on the trans to drain it only to realize that they could t get the top plug off, leaving them no way to refill the transmission with fluid. Once the transmission is drained pull the shift console. I believe it’s just two 10mm or two 13mm bolts holding it in. The shift rod on that console that goes into the transmission has a ‘finger’ on it that engages the gears. The finger is held onto that shift rod inside the transmission with a small roll pin that goes through the rod and the finger. If it’s all in one piece you can tilt the whole console to get it out. If the shift finger has sheared the pin the console will come out pretty easily and the finger should fall out after it. Hopefully the pin parts fall out, too. Inspect and see what’s needed. There are some seals to replace while you’re in there to help prevent leaks. I’d also check the bushings that the long shift rod rides in on the shifter console and replace. Cheap part but helps shift feel. Also there are bushings at the front of the shift rod. I’m assuming that since you have a side shifter trans that the front of the shift rod has the late style shift knuckle. That can be disassembled and the bushings replaces (search the site of how to do this without breaking the aluminum cage). Then go for a short drive...you’ll get a feel for what needs to get repaired. But get those rusted areas repaired quickly. Lots of help here and probably several people in your area here on the board willing to lend a hand. On a side note the 914 is incredibly blessed on the amount of parts that are available. Very, very few parts are unavailable. For instance you asked about the rubber bumper tops being available. The guy that replied that yes they were? Yeah, he’s the guy that makes them...and about a million other parts for the 914. You can visit his site (www.914rubber.com) but prepare your wallet to be decimated in short order. Thank you for the information about the shifter, my two sons are excited about getting to work on the car this weekend. My oldest son came home today from work and started taking the seats out to check the floor boards and replace the carpet . My youngest son is excited about getting to ride in it with the top off . I came home today and started trying to get an idea of what pieces I need to fix the hell hole, I really want to put the car up on the lift but I'm worried about bending the body or something , I have some 6"i-beams that I bought to build a frame table for my son's 36 Chevy, I thought about using them to make a table to put the car on and lift that . I plan on removing the rocker covers tomorrow to inspect underneath. Thanks for your help |
Lo-Fi Version | Time is now: 26th April 2024 - 08:07 PM |
