steering wheel, 1974 914 1.8............removal |
brcacti |
Sep 10 2019, 12:59 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, is there a video or directions how to remove momo steering wheel and stock steering wheel, want to fix blinker and MIGHT put stock wheel back on, which wheel do you all prefer?
Garland |
Sep 10 2019, 02:37 PM
Restoration Fanatic Group: Members Posts: 1,327 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
If you’ve ever noticed when the wheels attached and you pull it there’s some movement in and out. After removing the night you can pull the steering wheel towards you and tap the shaft back through the wheel. Not all in one motion, Pull tap, Pull tap, and the wheel will come free.
Extreme torque is not needed on the steering wheel bolt, as long as you depress the washer and the bold is snug. |
Lo-Fi Version | Time is now: 29th April 2024 - 12:53 AM |
