steering wheel, 1974 914 1.8............removal |
brcacti |
Sep 10 2019, 12:59 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, is there a video or directions how to remove momo steering wheel and stock steering wheel, want to fix blinker and MIGHT put stock wheel back on, which wheel do you all prefer?
mepstein |
Sep 10 2019, 01:26 PM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I like stock. Unscrew the nut a couple turns but leave a couple turns threaded. I’m pretty sure it’s a 25mm. Pull the wheel to break it loose. Leaving the nut loose on the shaft will keep it from m hitting you in the face if it requires a lot of force to remove. You can tap the back of the rim with a rubber mallet to get it started.
Don’t use the steering lock to hold the wheel when you remove the nut. It’s not meant for that much force. |
brcacti |
Sep 10 2019, 02:24 PM
I like stock. Unscrew the nut a couple turns but leave a couple turns threaded. I’m pretty sure it’s a 25mm. Pull the wheel to break it loose. Leaving the nut loose on the shaft will keep it from m hitting you in the face if it requires a lot of force to remove. You can tap the back of the rim with a rubber mallet to get it started. Don’t use the steering lock to hold the wheel when you remove the nut. It’s not meant for that much force. Do I need to take that center bolt off to repair blinkers and install new ignition switch? |
Lo-Fi Version | Time is now: 25th April 2024 - 10:06 AM |
