Spring choice and rear Sway |
Literati914 |
Sep 10 2019, 08:49 PM
Senior Member Group: Members Posts: 1,428 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Is there a point where a stiff(er) [than stock] rear spring negates the need for a rear sway bar? I've got a set of #140 welts that I'd been planning to use with or without a rear sway bar for sporty street car handling and probably some A/X.. but would jumping up to say a #180 spring and no sway bar be a better choice (both seem a bit much?).. or would it be better to use a stock rear sway bar and lighter springs?
yeahmag |
Sep 11 2019, 04:15 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I'm at 300lbs in the rear and am likely going to 400lbs.
Current setup: Raised spindles Rebel Racing Front and Rear (teflon) bushings COM14 spherical bearing (replacement for camber plates) 21 mm torsion bars 21 mm front sway bar 300lb rear springs |
Lo-Fi Version | Time is now: 19th April 2024 - 11:40 AM |
