Spring choice and rear Sway |
Literati914 |
Sep 10 2019, 08:49 PM
Senior Member Group: Members Posts: 1,396 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Is there a point where a stiff(er) [than stock] rear spring negates the need for a rear sway bar? I've got a set of #140 welts that I'd been planning to use with or without a rear sway bar for sporty street car handling and probably some A/X.. but would jumping up to say a #180 spring and no sway bar be a better choice (both seem a bit much?).. or would it be better to use a stock rear sway bar and lighter springs?
ConeDodger |
Sep 11 2019, 10:43 PM
Apex killer! Group: Members Posts: 23,543 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Mine is a 3.2 six conversion. I have 200# rear coil overs with stock front 4 cylinder torsion bars. All the bushings are Elephant which makes the car feel stockish on the road. I do use a stock rear sway bar and a Taret front bar. I like the front soft so I can tune with the Taret bar. If you have a four cylinder, your 140# Welts should be fine.
As you can see, at full song she handles perfectly flat. Attached image(s) |
Lo-Fi Version | Time is now: 28th March 2024 - 02:38 PM |
