Engine Options, Picking the right build for my 1.7. |
Gplracer |
Sep 11 2019, 10:09 AM
Newbie Group: Members Posts: 12 Joined: 8-September 19 From: Evans GA Member No.: 23,442 Region Association: South East States |
After a considerable amount of research it looks like the following three options are my best choices for a 1973 914 1.7L rebuild.
1. Rebuild the engine the with the same displacement. This would require honing out the cylinders and installing new pistons. 2. Rebuild the 1.7 as a 2056. This would require new cylinders, pistons, rods, 2.0 cam and possible matching to make the valves bigger. Then new valves. 3. Buy a 2.0L motor, increase to 2056 by buying new cylinders and new pistons. All of this assumes the heads are not cracked or need repairs. It appears that option 3 would be the best if I can get a 2.0 liter motor cheap. Plus option 3 would allow me to not have to split the case if there are not any issues. My car has been sitting for about 25 years and has around 80,000 miles on it. My dad was the original owner. The buyer never did anything with it. He parked it on a concrete slab with a roof over it and put a cover over it. Opinions and advise? |
Spoke |
Sep 11 2019, 05:36 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
3. Buy a 2.0L motor, increase to 2056 by buying new cylinders and new pistons. Opinions and advise? (IMG:style_emoticons/default/agree.gif) I took this route. For $850 I bought a 2L engine from Gerald Shaffer which included dual Weber carbs and Pertronix electronic points.. The plan was to punch it out to 2056. However when I took the heads off I found the pistons were already 96mm. I cleaned the engine up, put it all back together and fired it up. 3 years later it's still running good. |
Gplracer |
Sep 11 2019, 06:46 PM
3. Buy a 2.0L motor, increase to 2056 by buying new cylinders and new pistons. Opinions and advise? (IMG:style_emoticons/default/agree.gif) I took this route. For $850 I bought a 2L engine from Gerald Shaffer which included dual Weber carbs and Pertronix electronic points.. The plan was to punch it out to 2056. However when I took the heads off I found the pistons were already 96mm. I cleaned the engine up, put it all back together and fired it up. 3 years later it's still running good. Spoke, you got lucky with that. |
Lo-Fi Version | Time is now: 7th May 2024 - 05:45 PM |
