Gas line issue, sprung a leak |
johnpierre |
Sep 16 2019, 12:12 PM
Member Group: Members Posts: 401 Joined: 11-September 12 From: culver city, ca Member No.: 14,913 Region Association: Southern California |
hey everyone
its been a while - but im in need of some help. my fuel line sprung a leak. i notice a big puddle under the passenger side seat. when investigated i could smell gas. then i tried to start is and no luck out of gas. has this happened to anyone? is it as simple as just replacing the fuel line itstelf or can i just repair the area that is leaking? is this a straight forward/simple job that i can perform myself or is it for a true mechanic? please advice, much appreciated... -jp- |
bretth |
Sep 16 2019, 12:53 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
First of all don't try to start it anymore until the leak is fixed. Do you still have the original vinyl fuel lines on the car? They should be replaced with a set of hard stainless lines as sold by places like tangerine racing. Is possible that the lines by the fuel pump (if yours in front of the car) have sprung a leak also.
anderssj |
Sep 16 2019, 01:06 PM
Dog is my copilot... Group: Members Posts: 1,653 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
hey everyone i notice a big puddle under the passenger side seat. -jp- I'm assuming your leak is under the passenger side of the car... The last time my car sprung a leak in that location it was a crack in the fuel filter (small white plastic cube shape, 1 hose in, 1 hose out). The filter is just above the right end of the engine mounting bar. Before that, it was a crack in the rubber "reducer" hose in that same area. Chris at Tangerine makes a steel replacement ("fuel line adapter piece") for that one: http://www.tangerineracing.com/stainlessfuellines.htm Hope this helps! |
rjames |
Sep 16 2019, 01:37 PM
I'm made of metal Group: Members Posts: 3,917 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Please report back on what line is the culprit. I know many have replaced the gas lines in the tunnel with SS lines, but I don't recall hearing of any accounts where the tunnel lines were actually cracked and/or the source of a gas leak. The consensus seemed to be the opposite- that they were in good shape when people removed them.
That said, I will be replacing mine before too long. (IMG:style_emoticons/default/smile.gif) |
porschetub |
Sep 16 2019, 01:56 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Most likely the rubber lines of the plastic ones ,mine were pretty rotten and the rest was fine.
mepstein |
Sep 16 2019, 03:15 PM
914-6 GT in waiting Group: Members Posts: 19,244 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would replace every rubber and plastic line you can. They don’t get better with age. Same with the rubber soft lines for the brakes.
burton73 |
Sep 16 2019, 04:07 PM
burton73 Group: Members Posts: 3,508 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I would replace every rubber and plastic line you can. They don’t get better with age. Same with the rubber soft lines for the brakes. (IMG:style_emoticons/default/agree.gif) in a bigley way. Also if you are in Culver City there are a number of 914 brothers near you. Bob B |
SirAndy |
Sep 16 2019, 04:58 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
... then i tried to start is and no luck out of gas ... Why in the world would you do that? (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/blowup.gif) |
Tbrown4x4 |
Sep 16 2019, 11:17 PM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
An expensive repair , but weighed against the price of a new 914, it’s cheap. Replace all the rubber hoses with ethanol safe replacements, and replace the plastic hoses in the tunnel with stainless hard lines. Tangerine has them, but there is another vendor on 914World that also sells them. Do it right and sleep soundly.
Rand |
Sep 16 2019, 11:21 PM
Let this be clear. The problems with fuel systems are NOT the factory lines that everyone insists you have to replace them. The stock fuel lines really do work.
Sure, buy the right ones. Tangerine. Done. |
porschetub |
Sep 17 2019, 01:12 AM
(IMG:style_emoticons/default/agree.gif) my plastic stuff was fine,however my car has been sitting a long time with low mileage, use the best hose you can buy from the lines to the tank and use FI clamps ok.
iankarr |
Sep 17 2019, 01:16 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
There's a video on how to replace the fuel lines in my signature. Good luck and be safe!
Tbrown4x4 |
Sep 17 2019, 02:53 AM
You said, "i notice a big puddle under the passenger side seat". Did you mean UNDER the car or IN the car?
johnpierre |
Sep 17 2019, 03:40 PM
hey everyone
thanks for the reply's and help I will jack the car up and see if it is the lines or the filter as pointed out - will reply with the results soon. i know i could count on y'all (IMG:style_emoticons/default/aktion035.gif) |
ClayPerrine |
Sep 18 2019, 05:50 AM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Let this be clear. The problems with fuel systems are NOT the factory lines that everyone insists you have to replace them. The stock fuel lines really do work. I Vehemently Disagree! The plastic fuel line on Betty's 914 cracked where it comes out of the tunnel and turns toward the right side of the car. That sprayed gasoline over the hot engine, and we had an engine fire! We watched her car burn. The problem is not the lines in the tunnel, it is the part in the engine compartment. They become brittle and hard from age and heat, and they eventually will crack and leak. Stainless steel lines are cheap compared with a totally burned 914. |
johnpierre |
Sep 19 2019, 12:44 AM
Let this be clear. The problems with fuel systems are NOT the factory lines that everyone insists you have to replace them. The stock fuel lines really do work. I Vehemently Disagree! The plastic fuel line on Betty's 914 cracked where it comes out of the tunnel and turns toward the right side of the car. That sprayed gasoline over the hot engine, and we had an engine fire! We watched her car burn. The problem is not the lines in the tunnel, it is the part in the engine compartment. They become brittle and hard from age and heat, and they eventually will crack and leak. Stainless steel lines are cheap compared with a totally burned 914. crap... |
defianty |
Sep 19 2019, 02:28 AM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
The problem is not the lines in the tunnel, it is the part in the engine compartment. They become brittle and hard from age and heat, and they eventually will crack and leak. Totally agree. When I removed mine during my restoration one of the lines shattered like thin glass. |
johnpierre |
Oct 3 2019, 10:43 PM
I would replace every rubber and plastic line you can. They don’t get better with age. Same with the rubber soft lines for the brakes. (IMG:style_emoticons/default/agree.gif) in a bigley way. Also if you are in Culver City there are a number of 914 brothers near you. Bob B hey Bob - finally going to investigate the issue this weekend - good to know there are some peeps in CC if i need assistance. ill know more by Monday.. stay tuned. -jp- |
Mikey914 |
Oct 3 2019, 11:54 PM
The rubber man Group: Members Posts: 12,639 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
My money is on the rubber. I had a similar experience in the 912. factory lines from 76 were in great shape. Let it sit over the winter and realized the smell. Saw the drip.
Pretty sure the ethanol did it in. Had to replace all the lines in it, but really figured I should anyhow. I now only run clear in her. |
JawjaPorsche |
Oct 4 2019, 04:06 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I had a rare leak in the plastic tunnel lines. I replaced with Tangerine Racing stainless steel lines. Don’t drive your teener until all leaks are repaired.
Seeing the picture from above post is just amazing. Same original cloth lines! Yikes! Attached image(s) |
Lo-Fi Version | Time is now: 29th April 2024 - 08:00 AM |
