take out odometer question, 1974 914 1.8 |
brcacti |
Sep 16 2019, 02:01 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Do I need to take the steering wheel off to take the odometer out, not a real lot of room to pull the odometer off if I don't
porschetub |
Sep 16 2019, 02:04 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
brcacti |
Sep 16 2019, 06:57 PM
Thanks for the information
porschetub |
Sep 17 2019, 02:26 PM
Also forgot to mention your speedo may be stuck in the surround after being in there for years...mine was,the rubber ring gets sticky,if you can't move it take your fuel/combo gauge out first and then reach your speedo through that opening,helps to undo/refit the drive cable also,good luck.
mlindner |
Sep 17 2019, 03:05 PM
Senior Member Group: Members Posts: 1,516 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
porschetub, I'll second on the combo gauge out and push the speedo out.
Lo-Fi Version | Time is now: 3rd May 2024 - 11:32 PM |
