take out odometer question, 1974 914 1.8 |
brcacti |
Sep 16 2019, 02:01 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Do I need to take the steering wheel off to take the odometer out, not a real lot of room to pull the odometer off if I don't
porschetub |
Sep 17 2019, 02:26 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Also forgot to mention your speedo may be stuck in the surround after being in there for years...mine was,the rubber ring gets sticky,if you can't move it take your fuel/combo gauge out first and then reach your speedo through that opening,helps to undo/refit the drive cable also,good luck.
Lo-Fi Version | Time is now: 17th May 2024 - 08:42 PM |
