Feeling rich? One for the FI guys! |
Rod |
Sep 16 2019, 03:24 PM
Senior Member Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
Hi all, it’s a FI diagnosis I’m after, please help.
1973 1.7L standard FI system. When hot after a long run, I have a really rubbish tick-over and car wants to stall. I thought it would be MPS as mine has already been opened by a PO, but it reads 94 ohms on the outer coils and 398ohms on the inner terminals. It seems to hold vacuum too (only tried sucking on it, don’t have a gauge) so can I rule that out?? I really want some further checks to do as it’s running so rich I can see smoke at a hot idle and it’s difficult getting it to pull away without bogging down (only when hot - it’s great when cold!!) So it’s a hot only problem I’m having. Thanks for any help. |
rjames |
Sep 17 2019, 12:51 AM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Did you adjust the MPs for the proper AF ratios? If not, you need to.
Rod |
Sep 17 2019, 01:54 AM
Rand |
Sep 17 2019, 02:13 AM
Did you adjust the MPs for the proper AF ratios? If not, you need to. I have never had the MPS apart myself, it has screws on it rather than rivets though, so has been opened before obviously. I have no idea what settings it’s at. Go home. Substitute a known good MPS, try again. Report back. |
Lo-Fi Version | Time is now: 17th May 2024 - 01:49 PM |
