Feeling rich? One for the FI guys! |
Rod |
Sep 16 2019, 03:24 PM
Senior Member Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
Hi all, it’s a FI diagnosis I’m after, please help.
1973 1.7L standard FI system. When hot after a long run, I have a really rubbish tick-over and car wants to stall. I thought it would be MPS as mine has already been opened by a PO, but it reads 94 ohms on the outer coils and 398ohms on the inner terminals. It seems to hold vacuum too (only tried sucking on it, don’t have a gauge) so can I rule that out?? I really want some further checks to do as it’s running so rich I can see smoke at a hot idle and it’s difficult getting it to pull away without bogging down (only when hot - it’s great when cold!!) So it’s a hot only problem I’m having. Thanks for any help. |
rjames |
Sep 17 2019, 06:46 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
The MPS you get from Jeff will still most likely need to be adjusted to get the correct AFR for your engine. I just went through this myself. Tangerine Racing sells the MPS adjustment tools, but you will need an O2 sensor to know where your at. Plex makes a grood/affordable one that connects to your phone via Bluetooth if you don’t want to install a gauge.
Rod |
Sep 18 2019, 05:25 AM
The MPS you get from Jeff will still most likely need to be adjusted to get the correct AFR for your engine. I just went through this myself. Tangerine Racing sells the MPS adjustment tools, but you will need an O2 sensor to know where your at. Plex makes a grood/affordable one that connects to your phone via Bluetooth if you don’t want to install a gauge. My car is a factory standard 1.7 and I want this one to remain this way. Do I really need to set the MPS to this specific car? Are there not factory 1.7 settings that Jeff knows about? If they were sealed and set at the factory and teh car is standard I don't understand why the extra adjustment might be necessary.....? |
Lo-Fi Version | Time is now: 17th May 2024 - 06:18 PM |
