WTB: misc small-parts, For Grey Matter project |
theer |
Sep 17 2019, 05:05 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
I need a few small parts to keep going on the final assembly process for Grey Matter:
- (2) rear sail panel trim bottom mounting clips/brackets (need both sides) - - (2) heat/fresh air diffusers and mounting hardware- these are the plastic pieces up under the dash that split the "heat" from the mixer valves to the left & right. #11 in the diagram below: Let me know what you've got (ship to 02030) Thanks, Tom |
914Sixer |
Sep 17 2019, 05:53 PM
New pair Hella window handles on Ebay for $20
carl k |
Sep 17 2019, 08:16 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
I have one handle (Genuine) and the targa trim brackets. -Carl |
theer |
Sep 25 2019, 12:58 PM
Update: found everything except the sun visor mounts & pins.. anyone?
914_7T3 |
Sep 25 2019, 01:01 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Update: found everything except the sun visor mounts & pins.. anyone? @mikey914 from 914Rubber sells the full set. |
914Sixer |
Sep 26 2019, 06:05 AM
I have some used ones, just have to dig them out.
Mikey914 |
Sep 26 2019, 11:14 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Thanks for the props. We are the only ones who use stainless pins as you will see on used the visors scratch the chrome and they start to rust. They are also textured correctly too.
https://shop.914rubber.com/914-Visor-clip-s...m?categoryId=-1 I'll do a GB if I can get 5 takers at $75 a set of all 3. Just let me know if there is interest |
Lo-Fi Version | Time is now: 17th May 2024 - 07:13 PM |
