Thermostat day fun fun, little time to play but good result :). |
porschetub |
Sep 18 2019, 10:40 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Thanks to a well respected member on here I got a working thermostat ,big thanks to Mike B,got a mounting bracket on the way from the US,but getting close to running it up so preferred to have something.
Had a T1 unit with bracket so made the bracket to suit ...not easy ,tested closed with flaps tentioned. Thermostat expanded with small butane torch,bingo works perfect I could even here on the last part of movement the flaps hit the stops. Had a cable but the end didn't fit, to the bike shop for a nice SS Shimano cable for peanuts. More to follow, (IMG:style_emoticons/default/beer.gif) . Attached thumbnail(s) |
porschetub |
Nov 10 2019, 11:01 PM
Update,between other jobs I have sorta got this build done,minor things to finish.
Tried to clean the fan housing with the usual cleaners but no real success,split the assembly and give it a fine sandblast,worked well for coat of high temp silver. Real happy setting up Dellorto's...real easy,remember first start with basic setting and they just worked and run smooth with a timing change. Kinda wish I still had a bus to put it in (IMG:style_emoticons/default/sad.gif) ,the new owner will be happy. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:42 PM |
