Fuel Pump Replacement |
Michael34982 |
Oct 2 2019, 02:32 PM
I'm new here ... Group: Members Posts: 0 Joined: 2-October 19 From: Ft Pierce FL Member No.: 23,519 Region Association: None |
Hi,
I need a fuel Pump. Bosche part 61305, according to the new mechanic I found. Others say the dual line ones will work. Either way I need one for mu 1974 1.8 fuel injected 914. Thanks Mike |
ClayPerrine |
Oct 3 2019, 05:52 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Hi, I need a fuel Pump. Bosche part 61305, according to the new mechanic I found. Others say the dual line ones will work. Either way I need one for mu 1974 1.8 fuel injected 914. Thanks Mike Go to FLAPS and get an Airtex E8445 or equivalent. It is an aftermarket fuel pump that has the same volume and pressure specifications as the original. I have been running one on my wifes 74 1.8L 914 for about 6 years now. No issues at all with it. Good luck, Clay |
Lo-Fi Version | Time is now: 17th May 2024 - 02:51 PM |
