22 years later, How to restart after my own garage find. '73 1.7 |
914CLE |
Oct 2 2019, 03:46 PM
Newbie Group: Members Posts: 7 Joined: 19-September 19 From: Cleveland Member No.: 23,476 Region Association: Upper MidWest |
So after 22 years in my garage, I can finally get around to restarting. At this point, drained the gas, replaced all fuel line hoses and most vacuum lines, plugs look good, spark looks good, fuel is spraying from all injectors. Adjusted lifters. Car won't start. Any suggestions as to trouble shoot? I've ohm'd out coil (it's fine), voltage to coil is 10V (I think it's enough) as it main supply sparks, all cylinders has sparks. Turns over, no firing. Changed points to Petronix II. Still nothing even with staring fluid ( I would think if it was fuel delivery, it would at least fire for a few seconds with starting fluid).
It ran before I garaged it. Any suggestions, check lists to follow?? Do I need to hook up air filter and vacuum lines to get it to even start at a rough idle? |
JOEPROPER |
Oct 3 2019, 05:46 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Spark, fuel and compression are the key ingredients. (IMG:style_emoticons/default/agree.gif) with above, timing is probably not your problem unless you messed with it.
Superhawk996 |
Oct 3 2019, 06:17 PM
914 Guru Group: Members Posts: 5,778 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Spark, fuel and compression are the key ingredients. (IMG:style_emoticons/default/agree.gif) with above, timing is probably not your problem unless you messed with it. (IMG:style_emoticons/default/agree.gif) However . . . Initial post mentioned Pertronix so I suspect it was messed with. |
Lo-Fi Version | Time is now: 5th May 2024 - 02:56 AM |
