2 Pages V < 1 2
> Carbs, Weber 44s
cpavlenko
post Oct 5 2019, 08:50 PM
Post #21
OK, if I put a phenolic spacer between manifold and carb, it will raise the carb to where it will not allow the engine hood to close with rain tray. The more I think about on/off switch for the fuel pump the more I'm liking that solution. Besides, haven't found any spacers for type 4 engine. I'm assuming it will take bout 30 secs for car to run out off fuel to carb before turning key to off position.
yeahmag
post Oct 5 2019, 09:17 PM
Post #22
Take the rain tray off. You are fixing the symptoms with the fuel pump, not the problem.
cpavlenko
post Oct 5 2019, 09:48 PM
Post #23
QUOTE(yeahmag @ Oct 5 2019, 08:17 PM) *
Yes, ur right. Do have any ideal where to get the phenolic spacers between carb and intake manifold.
yeahmag
post Oct 5 2019, 10:02 PM
Post #24
The stock part will for the FI runners should do the trick.
MikeM
post Oct 6 2019, 08:05 AM
Post #25
Triangle Auto Supply in Yakima, Washington....
2 Pages V < 1 2
- Lo-Fi Version Time is now: 9th April 2026 - 10:33 AM
