Boxster "S" 6 speed trans |
partwerks |
Oct 5 2019, 02:50 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
The Boxster "S" 6 speed trans, that is used with the LS3 engine. Are all of the transaxles geared differently, or all the same?
Is anyone else running the Boxster "S" 6 speed, with an LS engine? |
tygaboy |
Oct 6 2019, 03:11 PM
914 Guru Group: Members Posts: 5,285 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Lyle - If you mean the shifter and associated cables, you can get a stock Boxster S shifter and cables on ebay for under $150. Here's one that's available now.
I splurged and got a Numeric shifter and cable set up. Not cheap, but super neat-o! |
partwerks |
Oct 6 2019, 05:36 PM
Lyle - If you mean the shifter and associated cables, you can get a stock Boxster S shifter and cables on ebay for under $150. Here's one that's available now. I splurged and got a Numeric shifter and cable set up. Not cheap, but super neat-o! I'm guessing the main body of the shifter operates differently than the 6, and needs to be changed along with the cables? How does the Audi/Passat 6 speed compare to the Boxster, or would that even work? |
Lo-Fi Version | Time is now: 4th May 2024 - 09:01 PM |
