Boxster "S" 6 speed trans |
partwerks |
Oct 5 2019, 02:50 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
The Boxster "S" 6 speed trans, that is used with the LS3 engine. Are all of the transaxles geared differently, or all the same?
Is anyone else running the Boxster "S" 6 speed, with an LS engine? |
Cracker |
Oct 8 2019, 05:44 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Ok. I called Kennedy Engineering today for you...I do not have good news. According to them, the base Boxster 5-speed adapter plate will not work with the Boxster S 6-speed. It does not matter whether or not you drilled the mounting holes.
The "kit" they sell includes everything needed to mate the 6-speed an LS engine. It costs about $2,800 + shipping. Good luck! Tony |
partwerks |
Oct 8 2019, 07:23 PM
Ok. I called Kennedy Engineering today for you...I do not have good news. According to them, the base Boxster 5-speed adapter plate will not work with the Boxster S 6-speed. It does not matter whether or not you drilled the mounting holes. The "kit" they sell includes everything needed to mate the 6-speed an LS engine. It costs about $2,800 + shipping. Good luck! Tony Thanks Tony! I am still waiting for a reply back from kitcarchassis.com, if the starter I now have, will work on the 6 speed, and my current adapter plate. So far this is what I have heard back: Yes, the 5 and 6 speed use the same holes. The early 6 speed uses a couple of less holes than the 5 speed and later 6 speed but they are located in the same places. You just need the correct clutch for which ever transmission you are using. I will have to check part numbers but I think you will need a full clutch kit. |
Lo-Fi Version | Time is now: 4th May 2024 - 10:25 PM |
