Boxster "S" 6 speed trans |
partwerks |
Oct 5 2019, 02:50 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
The Boxster "S" 6 speed trans, that is used with the LS3 engine. Are all of the transaxles geared differently, or all the same?
Is anyone else running the Boxster "S" 6 speed, with an LS engine? |
Cracker |
Oct 8 2019, 05:44 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Ok. I called Kennedy Engineering today for you...I do not have good news. According to them, the base Boxster 5-speed adapter plate will not work with the Boxster S 6-speed. It does not matter whether or not you drilled the mounting holes.
The "kit" they sell includes everything needed to mate the 6-speed an LS engine. It costs about $2,800 + shipping. Good luck! Tony |
partwerks |
Oct 8 2019, 07:23 PM
Ok. I called Kennedy Engineering today for you...I do not have good news. According to them, the base Boxster 5-speed adapter plate will not work with the Boxster S 6-speed. It does not matter whether or not you drilled the mounting holes. The "kit" they sell includes everything needed to mate the 6-speed an LS engine. It costs about $2,800 + shipping. Good luck! Tony Thanks Tony! I am still waiting for a reply back from kitcarchassis.com, if the starter I now have, will work on the 6 speed, and my current adapter plate. So far this is what I have heard back: Yes, the 5 and 6 speed use the same holes. The early 6 speed uses a couple of less holes than the 5 speed and later 6 speed but they are located in the same places. You just need the correct clutch for which ever transmission you are using. I will have to check part numbers but I think you will need a full clutch kit. |
andys |
Oct 9 2019, 09:28 AM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Ok. I called Kennedy Engineering today for you...I do not have good news. According to them, the base Boxster 5-speed adapter plate will not work with the Boxster S 6-speed. It does not matter whether or not you drilled the mounting holes. The "kit" they sell includes everything needed to mate the 6-speed an LS engine. It costs about $2,800 + shipping. Good luck! Tony Thanks Tony! I am still waiting for a reply back from kitcarchassis.com, if the starter I now have, will work on the 6 speed, and my current adapter plate. So far this is what I have heard back: Yes, the 5 and 6 speed use the same holes. The early 6 speed uses a couple of less holes than the 5 speed and later 6 speed but they are located in the same places. You just need the correct clutch for which ever transmission you are using. I will have to check part numbers but I think you will need a full clutch kit. Tony's got it right. The next statement in the post may confuse some, so......the 5 and 6 speeds use the same hole pattern if the 5 speed (Boxster) is the 012 version, and the 6 speed (Audi) is the 01E version. If I recall correctly, the 012 and the 01E use different clutch kits. They have nothing in common with the Boxster S 6 speed. Kennedy (KEP) is 5 minutes from my office. Andys |
partwerks |
Oct 9 2019, 06:28 PM
Ok. I called Kennedy Engineering today for you...I do not have good news. According to them, the base Boxster 5-speed adapter plate will not work with the Boxster S 6-speed. It does not matter whether or not you drilled the mounting holes. The "kit" they sell includes everything needed to mate the 6-speed an LS engine. It costs about $2,800 + shipping. Good luck! Tony Thanks Tony! I am still waiting for a reply back from kitcarchassis.com, if the starter I now have, will work on the 6 speed, and my current adapter plate. So far this is what I have heard back: Yes, the 5 and 6 speed use the same holes. The early 6 speed uses a couple of less holes than the 5 speed and later 6 speed but they are located in the same places. You just need the correct clutch for which ever transmission you are using. I will have to check part numbers but I think you will need a full clutch kit. Tony's got it right. The next statement in the post may confuse some, so......the 5 and 6 speeds use the same hole pattern if the 5 speed (Boxster) is the 012 version, and the 6 speed (Audi) is the 01E version. If I recall correctly, the 012 and the 01E use different clutch kits. They have nothing in common with the Boxster S 6 speed. Kennedy (KEP) is 5 minutes from my office. Andys According to the guy I got the adapter plate from (kitcarchassis.com) Yes, everything is the same except the clutch. The 6-speed has a larger input shaft. I would just need the clutch kit. (Spec SP892S) Clutch, PP, TOB, and he wasn't sure about the pilot bearing?? Said that 99-04 Boxster "S" are more favorable with taller gears. That would use a Spec SP892S for a stage 2 or a SP893S for a stage 3. The S on the end indicates a sprung clutch disc. I buy my clutches from this company, http://sohiperformance.com/ |
Lo-Fi Version | Time is now: 4th May 2024 - 03:11 PM |
