Boxster "S" 6 speed trans |
partwerks |
Oct 5 2019, 02:50 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
The Boxster "S" 6 speed trans, that is used with the LS3 engine. Are all of the transaxles geared differently, or all the same?
Is anyone else running the Boxster "S" 6 speed, with an LS engine? |
Mike Bellis |
Oct 13 2019, 10:24 PM
There are two (2) different 6 speed bellhousing bolt patterns.
One type looks similar to the 5 speed. The other is completely different and almost perfectly round (O), where as the 5/6 speed type is like a slanted "A" pattern. The "O" type is more often found on the LS motor. The "A" type is more often found on the SBC. Which transmission type do you have? What adapter kit do you have? SBC and LS are completely different and nothing swaps. Sounds like you're trying to put a square peg in a round hole. This has been going on for a year or more. I'm not understanding why you don't just buy the correct crap and finish the car. You're going to waste more money trying to fix the problem the just spending the $3k for the right kit. At the end you probably spend the $3k too. If you don't know what you're doing and your builder does not know what he is doing... You are wasting your money! Box up all the parts and ship it to someone that does. Embrace the suck... |
Lo-Fi Version | Time is now: 4th May 2024 - 10:36 PM |
